Datasheet TLV7031, TLV7032, TLV7034, TLV7041, TLV7042, TLV7044 (Texas Instruments)
ManufacturerTexas Instruments
DescriptionSmall-Size, Nanopower, Low-Voltage Comparators
Pages / Page67 / 1 — TLV7031,. TLV7032,. TLV7041,. TLV7042,. TLV7034,. TLV7044. TLV703x and …
File Format / SizePDF / 4.3 Mb
TLV7031,. TLV7032,. TLV7041,. TLV7042,. TLV7034,. TLV7044. TLV703x and TLV704x Small-Size, Nanopower, Low-Voltage Comparators
Datasheet TLV7031, TLV7032, TLV7034, TLV7041, TLV7042, TLV7044 Texas Instruments
link to page 1 link to page 1
TLV7031, TLV7032, TLV7041, TLV7042, TLV7034, TLV7044
SLVSE13I – SEPTEMBER 2017 – REVISED JUNE 2024
TLV703x and TLV704x Small-Size, Nanopower, Low-Voltage Comparators 1 Features
The benefit of fast response time at nanoPower • Ultra-small X2SON, WSON, WQFN packages enables power-conscious systems to monitor and • Tiny SOT-23, SC70, VSSOP, and TSSOP respond quickly to fault conditions. With an operating packages voltage range of 1.6V to 6.5V, these comparators are • Wide supply voltage range of 1.6V to 6.5V compatible with 3V and 5V systems. • Quiescent supply current of 315nA The TLV703x and TLV704x also ensure no output • Low propagation delay of 3µs phase inversion with overdriven inputs and internal • Rail-to-rail common-mode input voltage hysteresis, so engineers can use this family of • Internal hysteresis comparators for precision voltage monitoring in harsh, • Push-pull output (TLV703x) noisy environments where slow-moving input signals • Open-drain output (TLV704x) must be converted into clean digital outputs. • No phase reversal for overdriven inputs • –40°C to 125°C Operating temperature The TLV703x has a push-pull output stage capable of sinking and sourcing milliamps of current when
2 Applications
controlling an LED or driving a capacitive load. The TLV704x has an open-drain output stage that can • Mobile phones and tablets be pulled beyond V • Headsets/headphones & earbuds CC, making it appropriate for level translators and bipolar to single-ended converters. • PC & notebooks • Gas Detector
Device Information
• Smoke & heat detector
PACKAGE (PINS) BODY SIZE (NOM) PART NUMBERS
• Motion Detector (1) (2) • Gas Meter SOT-23 (5) 2.90mm × 1.60mm • Servo drive position sensor TLV7031, TLV7041 SC70 (5) 2.00mm × 1.25mm
3 Description
X2SON (5) 0.80mm × 0.80mm TLV7031L, TLV7041L SOT-23 (5) 2.90mm × 1.60mm The TLV7031/41 (single-channel), TLV7032/42 (dual- SC70 (5) 2.00mm × 1.25mm channel), and TLV7034/44 (quad-channel) are low- TLV7031S, TLV7041S SOT-23 (5) 2.90mm × 1.60mm voltage, nanoPower comparators. These devices are available in an ultra-small, leadless packages as VSSOP (8) 3.00mm x 3.00mm well as standard 5-pin SC70, SOT-23, VSSOP, and TLV7032, TLV7042 SOT-23 (8) 2.90mm x 1.60mm TSSOP packages, making them applicable for space- WSON (8) 2.00mm x 2.00mm critical designs like smartphones, smart meters, and WQFN (16) 3.00mm x 3.00mm other portable or battery-powered applications. TLV7034, TLV7044 TSSOP (14) 4.40mm x 5.00mm The TLV703x and TLV704x offer an excellent (1) For all available packages, see the orderable addendum at combination of speed and power, with a propagation the end of the data sheet. delay of 3μs and a quiescent supply current of 315nA. (2) The package size (length × width) is a nominal value and includes pins, where applicable. US dime (18x18x1.35 mm3) 0.6 5-Lead SC70 0.5 0.4 5-Pin X2SON ) A (P 0.3 CIC 0.2 0.1 Temp -40°C Temp 25°C Temp 125°C
X2SON Package vs SC70 and US Dime
0 1.5 2.5 3.5 4.5 5.5 6.5 VCC (V)
ICC vs. Supply Voltage
An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions Pin Functions Pin Functions: TLV7032/42 Pin Functions: TLV7034/44 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information (Single) 5.5 Thermal Information (Dual) 5.6 Thermal Information (Quad) 5.7 Electrical Characteristics (Single) 5.8 Switching Characteristics (Single) 5.9 Electrical Characteristics (Dual) 5.10 Switching Characteristics (Dual) 5.11 Electrical Characteristics (Quad) 5.12 Switching Characteristics (Quad) 5.13 Timing Diagrams 5.14 Typical Characteristics 6 Detailed Description 6.1 Overview 6.2 Functional Block Diagram 6.3 Feature Description 6.4 Device Functional Modes 6.4.1 Inputs 6.4.2 Internal Hysteresis 6.4.3 Output 7 Application and Implementation 7.1 Application Information 7.1.1 Inverting Comparator With Hysteresis for TLV703x 7.1.2 Noninverting Comparator With Hysteresis for TLV703x 7.2 Typical Applications 7.2.1 Window Comparator 7.2.1.1 Design Requirements 7.2.1.2 Detailed Design Procedure 7.2.1.3 Application Curve 7.2.2 IR Receiver Analog Front End 7.2.2.1 Design Requirements 7.2.2.2 Detailed Design Procedure 7.2.2.3 Application Curve 7.2.3 Square-Wave Oscillator 7.2.3.1 Design Requirements 7.2.3.2 Detailed Design Procedure 7.2.3.3 Application Curve 7.2.4 Quadrature Rotary Encoder 7.2.4.1 Design Requirements 7.2.4.2 Detailed Design Procedure 7.2.4.3 Application Curve 7.3 Power Supply Recommendations 7.4 Layout 7.4.1 Layout Guidelines 7.4.2 Layout Example 8 Device and Documentation Support 8.1 Device Support 8.1.1 Development Support 8.1.1.1 Evaluation Module 8.2 Documentation Support 8.2.1 Related Documentation 8.3 Receiving Notification of Documentation Updates 8.4 Support Resources 8.5 Trademarks 8.6 Electrostatic Discharge Caution 8.7 Glossary 9 Revision History 10 Mechanical, Packaging, and Orderable Information
