Datasheet LM285, LM385B (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | Micropower Voltage Reference Diodes |
Pages / Page | 10 / 1 — DATA SHEET. www.onsemi.com. MARKING. DIAGRAMS. SOIC−8. D SUFFIX. CASE … |
File Format / Size | PDF / 207 Kb |
DATA SHEET. www.onsemi.com. MARKING. DIAGRAMS. SOIC−8. D SUFFIX. CASE 751. TO−92. CASE 29−10. Features. Standard Application
link to page 6
DATA SHEET www.onsemi.com
Micropower Voltage
MARKING DIAGRAMS
Reference Diodes 8 LM285, LM385B
SOIC−8
y85−z 8
D SUFFIX
ALYW
CASE 751
G The LM285/LM385 series are micropower two−terminal bandgap 1 1 voltage regulator diodes. Designed to operate over a wide current range of 10 mA to 20 mA, these devices feature exceptionally low dynamic impedance, low noise and stable operation over time and temperature. Tight voltage tolerances are achieved by on−chip
TO−92
trimming. The large dynamic operating range enables these devices to
CASE 29−10
be used in applications with widely varying supplies with excellent regulation. Extremely low operating current make these devices ideal Pin: 1. N.C. for micropower circuitry like portable instrumentation, regulators and 2. Cathode other analog circuitry where extended battery life is required. 1 1 3. Anode 2 2 3 The LM285/LM385 series are packaged in a low cost TO−226 3 plastic case and are available in two voltage versions of 1.235 V and STRAIGHT LEAD BENT LEAD xxx = 1.2 or 2.5 2.500 V as denoted by the device suffix (see Ordering Information y = 2 or 3 table). The LM285 is specified over a −40°C to +85°C temperature z = 1 or 2 range while the LM385 is rated from 0°C to +70°C. A = Assembly Location The LM385 is also available in a surface mount plastic package in L = Wafer Lot voltages of 1.235 V and 2.500 V. Y = Year W = Work Week
Features
G = Pb−Free Package • (Note: Microdot may be in either location) Operating Current from 10 mA to 20 mA • 1.0%, 1.5%, 2.0% and 3.0% Initial Tolerance Grades • Low Temperature Coefficient (Bottom View) 1 8 N.C. Cathode • 1.0 W Dynamic Impedance 1 2 3 2 N.C. 7 N.C. • Surface Mount Package Available 3 6 N.C. N.C. • These Devices are Pb−Free and are RoHS Compliant 4 5 Anode N.C. Cathode
10 k 360 k + Open 1.5 V 3.3 k for 1.235 V Battery - 1.235 V 600 k LM385−1.2 8.45 k 74.3 k
ORDERING INFORMATION
600 k Open See detailed ordering and shipping information on page 6 of 425 k for 2.5 V this data sheet. 600 k 500 W 100 k Anode
Figure 1. Representative Schematic Diagram
© Semiconductor Components Industries, LLC, 2016
1
Publication Order Number:
April, 2022 − Rev. 11 LM285/D
