Datasheet LM4040 (Analog Devices) - 6
DescriptionImproved Precision Micropower Shunt Voltage Reference With Multiple Reverse Breakdown Voltages
Pages / Page17 / 6 — Electrical Characteristics—3.300V. PARAMETER. SYMBOL. CONDITIONS. MIN. …
Electrical Characteristics—3.300V. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Characteristics—3.300V PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
LM4040
LM4040 Improved Precision Micropower Shunt Voltage Reference with Multiple Reverse Breakdown Voltages
(IR = 100μA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
LM4040A (0.1%) 3.2967 3.3000 3.3033 LM4040B (0.2%) 3.2934 3.3000 3.3066 Reverse Breakdown Voltage VR TA = +25°C V LM4040C (0.5%) 3.2835 3.3000 3.3165 LM4040D (1.0%) 3.2670 3.3000 3.3330 LM4040A ±3.0 ±22 Reverse Breakdown Voltage LM4040B ±6.0 ±26 Tolerance (Note 2) VR mV LM4040C ±15 ±34 LM4040D ±30 ±59 LM4040A/B/C 45 67 Minimum Operating Current IRMIN µA LM4040D 45 70 IR = 10mA ±20 Average Reverse Voltage LM4040A/B/C ±15 ±100 Temperature Coefficient ∆VR/∆T IR = 1mA ppm/°C (Notes 2 and 3) LM4040D ±15 ±150 IR = 100µA ±15 LM4040A/B/C 0.3 1.0 Reverse Breakdown Voltage IRMIN ≤ I ≤ 1mA R LM4040D 0.3 1.2 Change with Operating mV Current Change LM4040A/B/C 2.5 8.0 1mA ≤ IR ≤ 15mA LM4040D 2.5 10.0 LM4040A/B 0.3 0.8 Reverse Dynamic IR = 1mA, f = 120Hz, Impedance (Note 3) ZR I LM4040C 0.3 0.9 Ω AC = 0.1IR LM4040D 0.3 1.1 Wideband Noise eN IR = 100µA, 10Hz ≤ f ≤ 10kHz 50 µVRMS Reverse Breakdown Voltage Long-Term Stability ∆VR T = 1000h 120 ppm www.maximintegrated.com Maxim Integrated │ 6
