Datasheet MAX6006B (Analog Devices)
Description1µA SOT23 Precision Shunt Voltage Reference
Pages / Page8 / 1 — here. MAX6006–MAX6009. 1µA SOT23 Precision Shunt. Voltage Reference. …
here. MAX6006–MAX6009. 1µA SOT23 Precision Shunt. Voltage Reference. General Description. Features. Applications
Datasheet MAX6006B Analog Devices
Click
here
for production status of specific part numbers.
MAX6006–MAX6009 1µA SOT23 Precision Shunt Voltage Reference General Description Features
The MAX6006–MAX6009 ultra-low-power shunt ● Ultra-Low Operating Current: Guaranteed < 1µA references are ideal for space-critical and low-power ● Small 3-Pin SOT23 Package applications. They are offered in 3-pin SOT23 packages, and the minimum operating current is guaranteed to be ● Initial Voltage Accuracy: 0.2% <1µA. The devices feature low temperature coefficients of ● Temperature Coefficient: 30ppm/°C max <30ppm/°C and initial accuracy of better than 0.2%. ● Temperature Range: -40°C to +85°C Available in +1.25V, +2.048V, +2.5V, and 3V output ● Factory-Trimmed Output Voltages: +1.25V, +2.048V, voltages, the MAX6006–MAX6009 have references of +2.5V, +3.0V +1.25V, +2.048V, +2.5V, and +3.0V, respectively. The devices can be used as lower-power, higher-precision ● Wide Operating Range: 1µA to 2mA upgrades to the ICL8069, LM385, LT1004, and LM4040 ● AEC-Q100 (MAX6008AEUR/V+ Only) references. The MAX6006–MAX6009 are available in two grades: A and B. The A grade features a temperature
Applications
coefficient of 30ppm/°C over the extended temperature ● Battery-Powered Equipment range of -40°C to +85°C, with an initial accuracy of ● Portable Meters 0.2%. Grade B features a temperature coefficient of ● Precision Regulators 75ppm/°C with an initial accuracy of 0.5%. MAX6006 in ● A/D and D/A Converters +1.25V and MAX6008 in +2.5V are offered in 8-pin SO packages, as plug in upgrades for LT1004 and LM285.
Ordering Information PART OUTPUT INITIAL TEMP COEFFICIENT VOLTAGE (V) ACCURACY (%) (ppm/°C) PIN-PACKAGE TOP MARK MAX6006
AEUR+T 1.25 0.2 30 3 SOT23 +FZGH MAX6006AESA+ 1.25 0.2 30 8 SO — MAX6006BEUR+T 1.25 0.5 75 3 SOT23 +FZGI MAX6006BESA+ 1.25 0.5 75 8 SO —
MAX6007
AEUR+T 2.048 0.2 30 3 SOT23 +FZGK MAX6007AESA+ 2.048 0.2 30 8 SO — +Denotes a lead(Pb)-free/RoHS-compliant package. T = Tape and reel.
Ordering Information continued at end of data sheet. Typical Operating Circuit Pin Configurations
VS TOP VIEW MAX6006 MAX6007 MAX6008 I MAX6009 RMIN + IL RBIAS IL
V OUT 1 N.C. 1 8 OUT R VOUT IRMIN 3 I.C. N.C. 2 7 N.C. MAX6006 MAX6007 0.01µF GND 2 N.C. 3 6 OUT MAX6008 MAX6009 GND 4 5 N.C.
SOT23
RBIAS = VS - VR I
SO
L + IRMIN 19-1730; Rev 4; 11/19
