Datasheet REF3425, REF3430, REF3433, REF3440, REF3450 (Texas Instruments) - 4
Description | Low-Drift, Low-Power, Small-Footprint Series Voltage Reference |
Pages / Page | 31 / 4 — REF3425. , REF3430, REF3433, REF3440, REF3450. www.ti.com. 5 Device … |
File Format / Size | PDF / 2.5 Mb |
REF3425. , REF3430, REF3433, REF3440, REF3450. www.ti.com. 5 Device Comparison Table. PRODUCT. VOUT
![REF3425 , REF3430, REF3433, REF3440, REF3450 www.ti.com 5 Device Comparison Table PRODUCT VOUT](https://www.rlocman.ru/datasheet/img.php?di=182769&p=3)
SBAS804F – SEPTEMBER 2017 – REVISED JUNE 2021
REF3425 REF3425T 2.5 V REF3430 REF3430T 3 V REF3433 REF3433T 3.3 V REF3440 REF3440T 4.096 V REF3450 REF3450T 5 V 4 Submit Document Feedback Copyright © 2021 Texas Instruments Incorporated Product Folder Links: REF3425 REF3430 REF3433 REF3440 REF3450 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Solder Heat Shift 8.2 Long-Term Stability 8.3 Thermal Hysteresis 8.4 Power Dissipation 8.5 Noise Performance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.3.1 Supply Voltage 9.3.2 Low Temperature Drift 9.3.3 Load Current 9.4 Device Functional Modes 9.4.1 EN Pin 9.4.2 Negative Reference Voltage 10 Application and Implementation 10.1 Application Information 10.2 Typical Application: Basic Voltage Reference Connection 10.2.1 Design Requirements 10.2.2 Detailed Design Procedure 10.2.2.1 Input and Output Capacitors 10.2.2.2 4-Wire Kelvin Connections 10.2.2.3 VIN Slew Rate Considerations 10.2.2.4 Shutdown/Enable Feature 10.2.3 Application Curves 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Documentation Support 13.1.1 Related Documentation 13.2 Receiving Notification of Documentation Updates 13.3 Support Resources 13.4 Trademarks 13.5 Electrostatic Discharge Caution 13.6 Glossary 14 Mechanical, Packaging, and Orderable Information
