Datasheet CRCW0603 (Vishay) - 2
ManufacturerVishay
DescriptionLead (Pb)-Bearing Thick Film Chip Resistors
Pages / Page10 / 2 — D/CRCW. APPLICATION INFORMATION. TEMPERATURE COEFFICIENT AND RESISTANCE …
File Format / SizePDF / 135 Kb
D/CRCW. APPLICATION INFORMATION. TEMPERATURE COEFFICIENT AND RESISTANCE RANGE TYPE / SIZE. TCR. TOLERANCE. RESISTANCE. E-SERIES
D/CRCW APPLICATION INFORMATION TEMPERATURE COEFFICIENT AND RESISTANCE RANGE TYPE / SIZE TCR TOLERANCE RESISTANCE E-SERIES
D/CRCW
www.vishay.com Vishay
When the resistor dissipates power, a temperature rise above the ambient temperature occurs, dependent on the thermal resistance of the assembled resistor together with the printed circuit board. The rated dissipation applies only if the permitted film temperature is not exceeded. These resistors do not feature a limited lifetime when operated within the permissible limits. However, resistance value drift increasing over operating time may result in exceeding a limit acceptable to the specific application, thereby establishing a functional lifetime.
± 200 ppm/K ± 5 % 1 Ω to 10 MΩ E24
D10/CRCW0402
± 100 ppm/K ± 1 % 1 Ω to 10 MΩ E24; E96 Jumper, Imax. = 1.5 A ≤ 20 mΩ 0 Ω - ± 200 ppm/K ± 5 % 1 Ω to 10 MΩ E24
D11/CRCW0603
± 100 ppm/K ± 1 % 1 Ω to 10 MΩ E24; E96 Jumper, Imax. = 2.0 A ≤ 20 mΩ 0 Ω - ± 200 ppm/K ± 5 % 1 Ω to 10 MΩ E24
D12/CRCW0805
± 100 ppm/K ± 1 % 1 Ω to 10 MΩ E24; E96 Jumper, Imax. = 2.5 A ≤ 20 mΩ 0 Ω - ± 200 ppm/K ± 5 % 1 Ω to 10 MΩ E24
D25/CRCW1206
± 100 ppm/K ± 1 % 1 Ω to 10 MΩ E24; E96 Jumper, Imax. = 3.5 A ≤ 20 mΩ 0 Ω - ± 200 ppm/K ± 5 % 1 Ω to 10 MΩ E24
CRCW1210
± 100 ppm/K ± 1 % 1 Ω to 10 MΩ E24; E96 Jumper, Imax. = 5.0 A ≤ 20 mΩ 0 Ω - ± 200 ppm/K ± 5 % 1 Ω to 2.2 MΩ E24
CRCW1218
± 100 ppm/K ± 1 % 1 Ω to 2.2 MΩ E24; E96 Jumper, Imax. = 7.0 A ≤ 20 mΩ 0 Ω - ± 200 ppm/K ± 5 % 1 Ω to 10 MΩ E24
CRCW2010
± 100 ppm/K ± 1 % 1 Ω to 10 MΩ E24; E96 Jumper, Imax. = 6.0 A ≤ 20 mΩ 0 Ω - ± 200 ppm/K ± 5 % 1 Ω to 10 MΩ E24
CRCW2512
± 100 ppm/K ± 1 % 1 Ω to 10 MΩ E24; E96 Jumper, Imax. = 7.0 A ≤ 20 mΩ 0 Ω -
Note
• The temperature coefficient of resistance (TCR) is not specified for 0 Ω jumpers Revision: 09-Jul-2024
2
Document Number: 20008 For technical questions, contact: thickfilmchip@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
