Datasheet SSL (Lumex)
ManufacturerLumex
DescriptionAxial LED
Pages / Page2 / 1 — PART NUMBER. REV. REV E.C.N. NUMBER AND REVISION COMMENTS. DATE. …
File Format / SizePDF / 582 Kb
PART NUMBER. REV. REV E.C.N. NUMBER AND REVISION COMMENTS. DATE. POLARITY. ELECTRO-OPTICAL CHARACTERISTIC TA=25. PARAMETER. MIN. TYP. MAX
Datasheet SSL Lumex
PART NUMBER
SSL-LXA228SRC-TR31
REV
H
REV E.C.N. NUMBER AND REVISION COMMENTS DATE
A CHG'D. LEDS LOCATION TO FIT SR STYLE 10.12.95 B E.C.N #10695. &10BRDR 01.05.01 2.50 0.098 C E.C.N #10745. 05.31.01 D E.C.N #10765. 06.18.01 E E.C.N #10784. 09.07.01 2 1 F E.C.N #11148. 11.15.06 G E.C.N #11668. 10.14.10 0.079 H ECN-Lumex202300046 09.20.22 2.00
POLARITY
1.90 ±0.10 0.075 ±0.004
PARAMETER MIN TYP MAX UNITS TEST COND PEAK WAVELENGTH
- 650 - nm If=20mA 2 1
FORWARD VOLTAGE
- 2.0 2.4 Vf If=20mA 5.80 0.228
REVERSE VOLTAGE
- - 5 Vr Ir=10uA 2.50 0.098 0.006
LUMINOUS INTENSITY
- 350 - mcd If=20mA
VIEWING ANGLE
- 25 - 2x theta1/2 - 0.150
EMITTED COLOR
RED 0.106
EPOXY LENS FINISH
WATER CLEAR 2.70
ABSOLUTE MAXIMUM RATINGS TA=25
℃ 4.30 0.169
PARAMETER MAX UNITS
0.058 0.055 0.030
PEAK FORWARD CURRENT*
60 mA 1.48 1.40
FORWARD CURRENT
20 mA 0.750
RECOMMENDED SOLDER PAD LAYOUT POWER DISIPATION
60 mW
STORAGE TEMPERATURE
-40 TO +100 ℃
OPERATING TEMPERATURE
-40 TO +85 ℃ 0.020
DUTY 1/10@1KHz 0.016 5.290 0.208 0.500 2 1 0.400 0.028 2- 0.700 2- 1.010 0.040 MOISTURE SENSITIVE DEVICE PER JEDEC LEVEL 4 STANDARDS *UNLESS OTHERWISE SPECIFIED TOLERANCES PER DECIMAL PRECISION ARE: X= + ±1 (±0.039), X.X=±0.5 (±0.020), X.XX=±0.25 (±0.010), X.XXX=±0.127 (±0.005). LEAD SIZE=±0.05 (±0.002), LEAD LENGTH=±0.75 (±0.030). MIN= MAX.= +DECIMAL PRECISION 0.00 -0.00 -DECIMAL PRECISION 425 N. GARY AVE. 2(L)*5.8(W)*2.7(H)mm, AXIAL LED, 650nm RED, WATER CLEAR LENS, TAPE & REEL. DATE: 2022.09.20 DRAWN BY:E.C. CAROL STREAM, IL 60188 PAGE: 1 OF 2 CHKD BY: T.S. PHONE:800-278-5666
**THE SPECIFICATIONS MAY CHANGE AT ANY TIME WITHOUT NOTICE.**
FAX:630-315-2150
CONFIDENTIAL INFORMATION
SCALE :
THE INFORMATION CONTAINED IN THIS DOCUMENT IS THE PROPERTY OF LUMEX INC. EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY LUMEX INC., THE HOLDER OF THIS DOCUMENT SHALL
NTF APRVD BY: G.Y WEB:WWW.LUMEX.COM
KEEP ALL INFORMATION CONTAINED HEREIN CONFIDENTIAL AND SHALL PROTECT SAME IN WHOLE OR IN PART FROM DISCLOSURE AND DISSEMINATION TO ALL THIRD PARTIES.
UNIT: mm [INCH] Pb
