Datasheet ISL60002 (Renesas)
ManufacturerRenesas
DescriptionPrecision Low Power FGA Voltage References
Pages / Page40 / 1 — VIN = +3.0V. 0.1µF. 10µF. VIN VOUT. 0.001µF. ISL60002-25. VOUT = 2.50V. …
File Format / SizePDF / 2.5 Mb
VIN = +3.0V. 0.1µF. 10µF. VIN VOUT. 0.001µF. ISL60002-25. VOUT = 2.50V. GND. REF IN. ENABLE. SERIAL. SCK. BUS. SDAT. 16 TO 24-BIT. A/D CONVERTER
Datasheet ISL60002 Renesas
link to page 35 link to page 35 link to page 34 link to page 1 DATASHEET ISL60002 FN8082 Rev.23.01 Precision Low Power FGA Voltage References Oct 16, 2019 The ISL60002 FGA voltage references are very high precision Features analog voltage references fabricated using the Renesas proprietary Floating Gate Analog (FGA) technology and feature • Reference voltages . 1.024V, 1.2V, 1.25V, 1.8V, 2.048V, low supply voltage operation at ultra-low 350nA operating 2.5V, 2.6V, 3.0V, and 3.3V current. • Absolute initial accuracy options . .±1.0mV, ±2.5mV, Additionally, the ISL60002 family features ensured initial and ±5.0mV accuracy as low as ±1.0mV and 20ppm/°C temperature • Supply voltage range coefficient. The initial accuracy and temperature stability - ISL60002-10, -11, -12, -18, -20, -25 . 2.7V to 5.5V performance of the ISL60002 family, plus the low supply - ISL60002-26 . 2.8V to 5.5V voltage and 350nA power consumption, eliminates the need to compromise thermal stability for reduced power - ISL60002-30 . 3.2V to 5.5V consumption, making it an ideal companion to high resolution, - ISL60002-33 . 3.5V to 5.5V low power data conversion systems. • Ultra-low supply current. 350nA typ Special Note: Post-assembly x-ray inspection can lead to • Low 20ppm/°C temperature coefficient permanent changes in device output voltage and should be • I minimized or avoided. For further information, please see SOURCE and ISINK = 7mA “Applications Information” on page 34 and AN1533, “X-Ray • ISOURCE and ISINK = 20mA for ISL60002-33 only Effects on FGA References”. • ESD protection . 5.5kV (Human Body Model) Applications • Standard 3 Ld SOT-23 packaging • High resolution A/Ds and D/As • Operating temperature range - ISL60002-10, -11, -12, -18, -20, -25, • Digital meters -26, -30 . -40°C to +85°C • Bar code scanners - ISL60002-33 . .-40°C to +105°C • Mobile communications • Pb-free (RoHS compliant) • PDAs and notebooks Related Literature • Medical systems For a full list of related documents, visit our website: • ISL60002 device page
VIN = +3.0V 0.1µF 10µF VIN VOUT 0.001µF ISL60002-25
(see Note 1)
VOUT = 2.50V GND REF IN ENABLE SERIAL SCK BUS SDAT 16 TO 24-BIT A/D CONVERTER
NOTE: 1. Also see Figure 118 on page 35 in Applications Information. FIGURE 1. TYPICAL APPLICATION FN8082 Rev.23.01 Page 1 of 40 Oct 16, 2019 Document Outline Applications Features Related Literature Table of Contents Pin Configuration Pin Descriptions Ordering Information Absolute Maximum Ratings Thermal Information Environmental Operating Conditions Recommended Operating Conditions Electrical Specifications ISL60002-10, VOUT = 1.024V Electrical Specifications ISL60002-11, VOUT = 1.200V Electrical Specifications ISL60002-12, VOUT = 1.250V Electrical Specifications ISL60002-18, VOUT = 1.800V Electrical Specifications ISL60002-20, VOUT = 2.048V Electrical Specifications ISL60002-25, VOUT = 2.500V Electrical Specifications ISL60002-26, VOUT = 2.600V Electrical Specifications ISL60002-30, VOUT = 3.000V Electrical Specifications ISL60002-33, VOUT = 3.300V Common Electrical Specifications ISL60002 -10, -11, -12, -18, -20, and -25 Typical Performance Characteristic Curves, VOUT = 1.024V Typical Performance Characteristic Curves, VOUT = 1.20V Typical Performance Characteristic Curves, VOUT = 1.25V Typical Performance Curves, VOUT = 1.8V Typical Performance Curves, VOUT = 2.048V Typical Performance Characteristic Curves, VOUT = 2.50V Typical Performance Characteristic Curves, VOUT = 3.0V Typical Performance Characteristic Curves, VOUT = 3.3V High Current Application Applications Information FGA Technology Nanopower Operation Board Mounting Considerations Board Assembly Considerations Special Applications Considerations Noise Performance and Reduction Turn-On Time Temperature Coefficient Typical Application Circuits Revision History Package Outline Drawing
