19-0458; Rev 1; 9/96 Low-Cost, Micropower, Precision, 3-Terminal,1.2V Voltage ReferenceMAX6120_______________General Description____________________________Features The MAX6120 is the lowest-power 1.2V, precision, ♦ 3-Pin SOT23 Package three-terminal voltage reference offered in a SOT23 package. Ideal for 3V battery-powered equipment ♦ Supply Current Independent of Input Voltage where power conservation is critical, the MAX6120 is a Over Temperature low-power alternative to existing two-terminal shunt ref- erences. Unlike two-terminal references that throw ♦ 50µA Supply Current away battery current and require an external series resistor, the MAX6120 has a 70µA maximum supply ♦ 2.4V to 11V Input Voltage Range current (typically only 50µA) that is independent of the ♦ 30ppm/°C Typical Tempco (SOT23) input voltage. This feature translates to maximum effi- ciency at all battery voltages. ♦ ±1% Initial Accuracy (SOT23) The MAX6120 operates from a supply voltage as low as 2.4V, and initial accuracy is ±1% for the SOT23 pack- age. Output voltage temperature coefficient is typically ______________Ordering Information only 30ppm/°C, and is guaranteed to be less than 100ppm/°C in the SOT23 package. For a guaranteed PARTTEMP. RANGEPIN-PACKAGE output voltage temperature coefficient of less than MAX6120ESA -40°C to +85°C 8 SO 50ppm/°C, see the MAX6520 data sheet. MAX6120EUR -40°C to +85°C 3 SOT23-3 ________________________Applications Battery-Powered Systems Portable and Hand-Held Equipment Data-Acquisition Systems _________________Pin Configurations Instrumentation and Process Control TOP VIEW V 1 IN 3 GND MAX6120 __________Typical Operating Circuit V 2 OUT V+ SOT23 2.4V to 11V VIN VOUT 1 8 VIN MAX6120 V 0.1µF V OUT OUT N.C. 1.2V 2 7 N.C. MAX6120 N.C. 3 6 N.C. GND 4 5 N.C. GND SO 0V ________________________________________________________________ Maxim Integrated Products1For free samples & the latest literature: http://www.maxim-ic.com, or phone 1-800-998-8800
