Datasheet NN03-410 (Ignion) - 2
ManufacturerIgnion
DescriptionOmnia Mxtendtm: A Standard Antenna Solution For Mobile Frequency Bands.
Pages / Page5 / 2 — OMNIA. mXTENDTM:. STANDARD. ANTENNA. SOLUTION FOR MOBILE FREQUENCY BANDS. …
File Format / SizePDF / 451 Kb
OMNIA. mXTENDTM:. STANDARD. ANTENNA. SOLUTION FOR MOBILE FREQUENCY BANDS. TOP. BOTTOM. Material:. Most used industries. Smart Metering
OMNIA mXTENDTM: STANDARD ANTENNA SOLUTION FOR MOBILE FREQUENCY BANDS TOP BOTTOM Material: Most used industries Smart Metering
USER MANUAL OMNIA mXTENDTM (NN03-410)
OMNIA mXTENDTM: A STANDARD ANTENNA SOLUTION FOR MOBILE FREQUENCY BANDS.
The OMNIA mXTEND™ chip antenna component is engineered to provide high-performance multiband coverage in wireless devices, supporting a wide array of communication standards across Cellular, GNSS, and Wi-Fi/BLE technologies. This versatile antenna solution allows for seamless integration into devices that require robust, multi-frequency operation while minimizing design complexity.
The OMNIA mXTENDTM chip antenna component is built on glass epoxy substrate.
Smart Metering
Industrial IoT
Automotive Telematics
Asset Tracking & Logistics OMNIA mXTEND™ benefits.
High Performance:
Provides reliable and consistent signal strength across Cellular, GNSS, and Wi-Fi/BLE, ensuring robust connectivity even in challenging environments. •
Multiband:
Supports a broad range of frequencies, ensuring global compatibility for mobile, location-based, and data transmission services. •
Simplified Integration:
A single antenna part with a triple-port configuration reduces the need for multiple components, simplifying your design and lowering costs. •
Reliability:
An off-the-shelf standard product that requires no customization, allowing for quicker deployment and reduced time-to-market.
Operation bands summary.
The OMNIA mXTEND™ SMD antenna component covers a broad spectrum of frequencies, ensuring comprehensive support for Cellular Networks (4G, 5G, NB-IoT, LTE-M), GNSS Systems (GPS, GLONASS, Galileo, BeiDou), and Wi-Fi/BLE and many more within the range of 400 MHz to 8000 MHz. 2 Last Update: October 2024 Document Outline 1 AVAILABLE CONFIGURATIONS SUMMARY 2 DETAILED AVAILABLE CONFIGURATIONS 2.1 CELLULAR IoT + GNSS + Wi-Fi/BLE CONFIGURATION
