Datasheet MAX6066 (Analog Devices) - 5
DescriptionPrecision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References
Pages / Page16 / 5 — Precision, Micropower, Low-Dropout,. High-Output-Current, SOT23 Voltage …
File Format / SizePDF / 559 Kb
Precision, Micropower, Low-Dropout,. High-Output-Current, SOT23 Voltage References. MAX6061–MAX6068
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References MAX6061–MAX6068
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References MAX6061–MAX6068 ELECTRICAL CHARACTERISTICS—MAX6066, VOUT = 2.500V
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6066A (0.2%) 2.495 2.500 2.505 Output Voltage VOUT TA = +25°C V MAX6066B (0.4%) 2.490 2.500 2.510 MAX6066A 6 20 Output Voltage Temperature TCVOUT ppm/°C Coefficient (Note 2) MAX6066B 6 30 ∆VOUT/ Line Regulation (VOUT + 0.2V) ≤ VIN ≤ 12.6V 60 300 µV/V ∆VIN Sourcing: 0 ≤ IOUT ≤ 5mA 0.5 0.9 ∆VOUT/ Load Regulation mV/mA ∆IOUT Sinking: -2mA ≤ IOUT ≤ 0 1.6 5 VIN - Dropout Voltage (Note 4) IOUT = 1mA 50 200 mV VOUT Short to GND 25 OUT Short-Circuit Current ISC mA Short to IN 25 ∆VOUT/ ppm/ Long-Term Stability 1000hr at +25°C 62 time 1000hr Output Voltage Hysteresis ∆VOUT/ 130 ppm (Note 3) cycle
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 27 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 30 µVRMS ∆VOUT/ Ripple Rejection VIN = 5V ±100mV, f = 120Hz 86 dB ∆VIN Turn-On Settling Time tR To VOUT = 0.1% of final value, COUT = 50pF 115 µs
INPUT CHARACTERISTICS
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 90 125 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 3.3 8.0 µA/V
_______________________________________________________________________________________ 5
