Datasheet MAX6066 (Analog Devices) - 10
DescriptionPrecision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References
Pages / Page16 / 10 — Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage …
File Format / SizePDF / 559 Kb
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References. Typical Operating Characteristics
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References Typical Operating Characteristics
(VIN = +5V for MAX6061–MAX6068, VIN = +5.5V for MAX6065, IOUT = 0, TA = +25°C, unless otherwise noted.) (Note 5)
MAX6062 MAX6065 MAX6061 OUTPUT VOLTAGE TEMPERATURE DRIFT OUTPUT VOLTAGE TEMPERATURE DRIFT LINE REGULATION
300 2.051 5.003 THREE TYPICAL PARTS THREE TYPICAL PARTS TA = +25°C V) 200 2.050 5.002 µ MAX6061/68 toc03 MAX6061/68 toc01 MAX6061/68 toc02 100 2.049 5.001 TA = +85°C 0 TA = -40°C 2.048 5.000 -100 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE CHANGE ( 2.047 4.999 -200 2.046 4.998 -300 -40 -15 10 35 60 85 -40 -15 10 35 60 85 2 4 6 8 10 12
MAX6061–MAX6068
TEMPERATURE (°C) TEMPERATURE (°C) INPUT VOLTAGE (V)
MAX6065 MAX6061 MAX6065 LINE REGULATION LOAD REGULATION LOAD REGULATION
200 5 12 0 4 10 TA = +85°C µV) MAX6061/68 toc04 T T A = -40°C A = +85°C 3 MAX6061/68 toc05 8 MAX6061/68 toc06 -200 6 2 -400 TA = +85°C 4 1 T -600 TA = -40°C A = +25°C 2 TA = +25°C 0 TA = +25°C -800 0 -1 OUTPUT VOLTAGE CHANGE ( OUTPUT VOLTAGE CHANGE (mV) -2 OUTPUT VOLTAGE CHANGE (mV) -1000 -2 -4 TA = -40°C -1200 -3 -6 5 7 9 11 13 -4 -2 0 2 4 -6 -4 -2 0 2 4 6 INPUT VOLTAGE (V) LOAD CURRENT (mA) LOAD CURRENT (mA)
MAX6066 MAX6065 MAX6061 DROPOUT VOLTAGE DROPOUT VOLTAGE POWER-SUPPLY REJECTION RATIO vs. LOAD CURRENT vs. LOAD CURRENT vs. FREQUENCY
0.25 0 0.30 -10 T 0.25 A = +85°C TA = +85°C 0.20 MAX6061/68 toc08 -20 MAX6061/68 toc09 MAX6061/68 toc07 -30 0.20 T 0.15 A = +25°C TA = +25°C -40 0.15 TA = -40°C PSRR (dB) -50 0.10 -60 0.10 DROPOUT VOLTAGE (V) DROPOUT VOLTAGE (V) TA = -40°C -70 0.05 0.05 -80 0 0 -90 0 1 2 3 4 5 0 1 2 3 4 5 0.001 0.01 0.1 1 10 100 1000 LOAD CURRENT (mA) LOAD CURRENT (mA) FREQUENCY (kHz)
10 ______________________________________________________________________________________
