Datasheet ADRF5010 (Analog Devices) - 3
DescriptionSilicon SPST Switch, NonReflective, 100 MHz to 55 GHz
Pages / Page12 / 3 — ADRF5010. SPECIFICATIONS. Table 1. Electrical Specifications. Parameter. …
File Format / SizePDF / 665 Kb
ADRF5010. SPECIFICATIONS. Table 1. Electrical Specifications. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit. analog.com
ADRF5010 SPECIFICATIONS Table 1 Electrical Specifications Parameter Symbol Test Conditions/Comments Min Typ Max Unit analog.com
link to page 4 link to page 4 link to page 4 link to page 4 Data Sheet
VDD = 3.3 V, VSS = −3.3 V, VCTRL = 0 V or VDD, TCASE = 25°C, 50 Ω system, unless otherwise noted. RFx refers to RF1 or RF2.
Table 1. Electrical Specifications Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE f 0.1 55 GHz INSERTION LOSS Between RFx and RFx (On) 0.1 GHz to 20 GHz 1.0 dB 20 GHz to 40 GHz 1.5 dB 40 GHz to 55 GHz 2.0 dB ISOLATION Between RFx and RFx 0.1 GHz to 20 GHz 31 dB 20 GHz to 40 GHz 30 dB 40 GHz to 55 GHz 28 dB RETURN LOSS RFx (Through path) 0.1 GHz to 20 GHz 20 dB 20 GHz to 40 GHz 19 dB 40 GHz to 55 GHz 21 dB RFx (Terminated) 0.1 GHz to 55 GHz 22 dB SWITCHING Rise Time and Fall Time tRISE,tFALL 10% to 90% of RF output 27 ns On Time and Off Time tON, tOFF 50% VCTL to 90% of RF output 30 ns RF Settling Time (0.1dB) 50% VCTL to 0.1 dB of final RF output 50 ns INPUT LINEARITY1 f = 0.1 GHz to 55 GHz Input Compression P0.1dB 33 dBm Third-Order Intercept IP3 Two-tone input power = 14 dBm each tone, Δf = 1 62 dBm MHz SUPPLY CURRENT VDD and VSS pins Positive Supply Current IDD 140 µA Negative Supply Current ISS 500 µA DIGITAL CONTROL INPUTS CTRL Voltage Low VINL 0 0.8 V High VINH 1.2 3.3 V Current Low IINL, <1 µA High IINH <1 µA RECOMMENDED OPERATING CONDITONS Supply Voltage Positive Supply Voltage VDD 3.15 3.45 V Negative Supply Voltage VSS −3.45 −3.15 V Digital Control Inputs Voltage VCTRL 0 VDD V RF INPUT POWER2 PIN f = 0.1 GHz to 55 GHz, TCASE = 85°C Peak3 36 dBm Through Path Pulse4 RF signal is applied to RFx at Insertion Loss state 33 dBm CW 30 dBm Peak 33 dBm Terminated Path Pulse RF signal is applied to RFx at Isolation state 33 dBm CW 30 dBm Peak 33 dBm Hot Switching Pulse RF signal is applied to RFx while switching in 33 dBm between Insertion Loss and Isolation states
analog.com Rev. 0 | 3 of 12
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curves Electrostatıc Dıscharge (ESD) Ratıngs ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input And Output Applications Information Evaluation Board Recommendatıons For Printed Circuit Board Design Outline Dimensions Ordering Guide Evaluation Boards
