link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 Data Sheet ADRF5031SPECIFICATIONS VDD = 3.3 V, VSS = −3.3 V, CTRL voltage (VCTRL) = 0 V or VDD, and TCASE = 25°C for a 50 Ω system, unless otherwise noted. RFx refers to RF1 or RF2. Table 1. Electrical CharacteristicsParameterSymbolTest Conditions/CommentsMinTypMaxUnit FREQUENCY RANGE f 0.009 20000 MHz INSERTION LOSS Between RFC and RFx (On) 9 kHz to 6 GHz 0.6 dB 6 GHz to 12 GHz 0.8 dB 12 GHz to 20 GHz 1.05 dB RETURN LOSS 9 kHz to 20 GHz RFC 22 dB RFx (On) 20 dB RFx (Off) 17 dB ISOLATION Between RFC to RFx and RFx to RFx 9 kHz to 6 GHz 55 dB 6 GHz to 12 GHz 50 dB 12 GHz to 20 GHz 45 dB SWITCHING Rise and Fall Time tRISE, tFALL 10% to 90% of RF output 3.0 µs On and Off Time tON, tOFF 50% VCTRL to 90% of RF output 5.0 µs Settling Time (0.1 dB) 50% VCTRL to 0.1 dB of final RF output 5.3 µs INPUT LINEARITY1 f = 1 MHz to 20 GHz Input Compression P0.1dB 35 dBm Third-Order Intercept IP3 Two-tone input power = 14 dBm each tone, f = 1 MHz 62 dBm to 20 GHz, Δf = 1 MHz Second-Order Intercept IP2 Two-tone input power = 14 dBm each tone, f = 8 GHz, 116 dBm Δf = 1 MHz VIDEO FEEDTHROUGH 4.5 mV p-p SUPPLY CURRENT VDD and VSS pins Positive Supply Current IDD 150 µA Negative Supply Current ISS 520 µA DIGITAL CONTROL INPUTS CTRL and EN pins Voltage Low VINL 0 0.8 V High VINH 1.2 3.3 V Current Low IINL <1 µA High IINH 33 µA RECOMMENDED OPERATING CONDITIONS Supply Voltage Positive VDD 3.15 3.45 V Negative VSS −3.45 −3.15 V Digital Control Inputs Voltage VCTRL 0 VDD V RF Input Power2, 3 PIN f = 1 MHz to 20 GHz, TCASE = 85°C Through Path RF signal is applied to RFC or through connected RFx Average (RF1 or RF2) 33 dBm Peak, Pulse4, 5 35 dBm Terminated Path RF signal is applied to unselected RFx (terminated Average within internal resistor) 30 dBm Peak, Pulse 32 dBm analog.comRev. A | 3 of 12 Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curve Electrostatic Discharge (ESD) Ratings ESD Ratings for the ADRF5031 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input and Output Power Supply Applications Information Recommendations for PCB Design Outline Dimensions Ordering Guide Evaluation Boards
