Datasheet ADRF5031 (Analog Devices) - 6
Description9 kHz to 20 GHz, Nonreflective, Silicon SPDT Switch
Pages / Page12 / 6 — ADRF5031. ABSOLUTE MAXIMUM RATINGS. ELECTROSTATIC DISCHARGE (ESD) RATINGS
File Format / SizePDF / 607 Kb
ADRF5031 ABSOLUTE MAXIMUM RATINGS ELECTROSTATIC DISCHARGE (ESD) RATINGS
Data Sheet
The following ESD information is provided for handling of ESD-sen- sitive devices in an ESD-protected area only. Human body model (HBM) per ANSI/ESDA/JEDEC JS-001. Charged device model (CDM) ratings are per ANSI/ESDA/JEDEC JS-002.
ESD Ratings for the ADRF5031 Table 5. ADRF5031, 20-Terminal LGA ESD Model Withstand Threshold (V) Class
HBM 4 kV for the RFx and RFC pins 3A 4 kV for the supply and digital control pins 3A CDM 500 V for all pins C2A
ESD CAUTION ESD (electrostatic discharge) sensitive device
. Charged devi- ces and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjected to high energy ESD. Therefore, proper ESD precautions should be taken to avoid performance degradation or loss of functionality.
analog.com Rev. A | 6 of 12
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curve Electrostatic Discharge (ESD) Ratings ESD Ratings for the ADRF5031 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input and Output Power Supply Applications Information Recommendations for PCB Design Outline Dimensions Ordering Guide Evaluation Boards
