Datasheet ADRF5031 (Analog Devices) - 9
Description9 kHz to 20 GHz, Nonreflective, Silicon SPDT Switch
Pages / Page12 / 9 — ADRF5031. TYPICAL PERFORMANCE CHARACTERISTICS. INPUT POWER COMPRESSION …
File Format / SizePDF / 607 Kb
ADRF5031. TYPICAL PERFORMANCE CHARACTERISTICS. INPUT POWER COMPRESSION AND THIRD-ORDER INTERCEPT
ADRF5031 TYPICAL PERFORMANCE CHARACTERISTICS INPUT POWER COMPRESSION AND THIRD-ORDER INTERCEPT
Data Sheet
VDD = 3.3 V, VSS = −3.3 V, VCTRL = 0 V or VDD, and TCASE = 25°C for a 50 Ω system, unless otherwise noted.
Figure 12. Input P0.1dB vs. Frequency Figure 14. Input P0.1dB vs. Frequency (Low-Frequency Detail) Figure 13. Input IP3 vs. Frequency Figure 15. Input IP3 vs. Frequency (Low-Frequency Detail) analog.com Rev. A | 9 of 12
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curve Electrostatic Discharge (ESD) Ratings ESD Ratings for the ADRF5031 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input and Output Power Supply Applications Information Recommendations for PCB Design Outline Dimensions Ordering Guide Evaluation Boards
