Datasheet MAX6138 (Analog Devices) - 4
Description | 0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages |
Pages / Page | 13 / 4 — Electrical Characteristics—MAX6138_30 (3.0V). PARAMETER. SYMBOL. … |
File Format / Size | PDF / 2.4 Mb |
Electrical Characteristics—MAX6138_30 (3.0V). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
MAX6138 0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages
(IR = 100μA, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6138A (0.1%) 2.9970 3.0000 3.0030 Reverse Breakdown Voltage (Note 2) VR TA = +25°C MAX6138B (0.2%) 2.9940 3.0000 3.0060 V MAX6138C (0.5%) 2.9850 3.0000 3.0150 Minimum Operating Current IRMIN 45 65 µA Reverse Voltage Temperature Coefficient TC 4 25 ppm/°C (Notes 2, 3) Reverse Breakdown IRMIN ≤ IR ≤ 1mA 0.3 1.0 Voltage Change with ∆VR/∆IR mV Operating Current Change 1mA ≤ IR ≤ 15mA 2.5 8.0 Reverse Dynamic Impedance (Note 3) ZR IR = 1mA, f =120Hz, IAC = 0.1IR 0.3 0.8 Ω Wideband Noise eN 10Hz ≤ f ≤ 10kHz 45 µVRMS Reverse Breakdown Voltage Long-Term Stability ∆VR t = 1000h 120 ppm
Electrical Characteristics—MAX6138_33 (3.3V)
MAX6138A (0.1%) 3.2967 3.3000 3.3033 Reverse Breakdown Voltage (Note 2) VR TA = +25°C MAX6138B (0.2%) 3.2934 3.3000 3.3066 V MAX6138C (0.5%) 3.2835 3.3000 3.3165 Minimum Operating Current IRMIN 45 67 µA Reverse Voltage Temperature Coefficient TC 4 25 ppm/°C (Notes 2, 3) Reverse Breakdown IRMIN ≤ IR ≤ 1mA 0.3 1.0 Voltage Change with ∆VR/∆IR mV Operating Current Change 1mA ≤ IR ≤ 15mA 8.0 Reverse Dynamic Impedance (Note 3) ZR IR = 1mA, f =120Hz, IAC = 0.1IR 0.3 0.8 Ω Wideband Noise eN 10Hz ≤ f ≤ 10kHz 50 µVRMS Reverse Breakdown Voltage Long-Term Stability ∆VR t = 1000h 120 ppm www.maximintegrated.com Maxim Integrated │ 4
