Datasheet MAX6173 (Analog Devices) - 9
DescriptionHigh-Precision Voltage References with Temperature Sensor
Pages / Page20 / 9 — Typical Operating Characteristics (continued). LINE REGULATION vs. …
File Format / SizePDF / 4.1 Mb
Typical Operating Characteristics (continued). LINE REGULATION vs. TEMPERATURE. LINE REGULATION. (VOUT = 2.5V)
Typical Operating Characteristics (continued) LINE REGULATION vs TEMPERATURE LINE REGULATION (VOUT = 2.5V)
MAX6173–MAX6177 High-Precision Voltage References with Temperature Sensor
(VIN = +5V for VOUT = +2.5V, VIN = +15V for VOUT = 4.096V and VOUT = +10V, IOUT = 0, TA = +25°C, unless otherwise noted.)
LINE REGULATION vs. TEMPERATURE LINE REGULATION LINE REGULATION vs. TEMPERATURE (VOUT = 2.5V) vs. TEMPERATURE (VOUT = 4.096V) (V
toc7b
OUT = 10V)
100 100 300 T 80 A = +65°C V) 80 T 250 MAX6173 toc07 A = -40°C MAX6173 toc08 T 60 TA = +125°C A = -40°C TA = -10°C 200 60 40 TA = +125°C 20 150 TA = -40°C 40 0 T T A = +100°C A = +25°C 100 -20 20 OUTPUT VOLTAGE CHANGE (µV) OUTPUT VOLTAGE VARIATION ( TA = +125°C 50 OUTPUT VOLTAGE CHANGE (µV) T -40 T A = +25°C A = +25°C C 0 LOAD = NO LOAD -60 0 0 5 10 15 20 25 30 35 40 0 10 20 30 40 12 16 20 24 28 32 36 40 INPUT VOLTAGE (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V)
MINIMUM INPUT-OUTPUT DIFFERENTIAL MINIMUM INPUT-OUTPUT DIFFERENTIAL MINIMUM INPUT-OUTPUT DIFFERENTIAL vs. SOURCE CURRENT (V vs. SOURCING CURRENT (V OUT = 2.5V) OUT = 4.096V) vs. SOURCE CURRENT (VOUT = 10V)
2.5 2.5 toc9a 2.5 MAX6173 toc09 MAX6173 toc10 2.0 2.0 2.0 TA = -40°C TA = -40°C TA = -40°C 1.5 1.5 1.5 TA = +25°C T T A = +25°C A = +25°C DROPOUT VOLTAGE (V) DROPOUT VOLTAGE (V) 1.0 T T A = +125°C 1.0 A = +125°C DROPOUT VOLTAGE (V) 1.0 TA = +125°C 0.5 0.5 0.5 0 4 8 12 16 20 0 4 8 12 16 20 0 4 8 12 16 20 SOURCE CURRENT (mA) SOURCE CURRENT (mA) SOURCE CURRENT (mA)
POWER-SUPPLY REJECTION RATIO POWER-SUPPLY REJECTION RATIO vs. FREQUENCY (VOUT = 2.5V) vs. FREQUENCY (VOUT = 10V) PSRR vs. FREQUENCY
toc12a 0 0 0 -10 VOUT = 4.096V -20 -20 -20 MAX6173 toc11 MAX6173 toc12 -30 -40 -40 -40 -60 -50 -60 -60 PSRR (dB) PSRR (dB) -80 PSRR (dB) -70 -80 -80 -100 -90 -120 -100 -100 -110 -140 -120 -120 0.001 0.01 0.1 1 10 100 1000 0.001 0.01 0.1 1 10 100 1000 0.001 0.01 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz) www.maximintegrated.com Maxim Integrated │ 9 Document Outline _GoBack
