Datasheet MAX6225, MAX6241, MAX6250 (Analog Devices) - 4
DescriptionLow-Noise, Precision, +2.5V/+4.096V/+5V Voltage References
Pages / Page11 / 4 — Electrical Characteristics—MAX6241. PARAMETER. SYMBOL. CONDITIONS. MIN. …
Electrical Characteristics—MAX6241. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Characteristics—MAX6241 PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6225/MAX6241/MAX6250 Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage References
(VIN = +10V, IOUT = 0mA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS TA MIN TYP MAX UNITS
Input Voltage Range VIN C, E, M 8 36 V MAX6241A +25°C 4.095 4.096 4.097 Output Voltage VOUT MAX6241B +25°C 4.092 4.096 4.100 V MAX6241AC_A C 1.0 2.0 MAX6241AE_A E 1.5 3.0 Output Voltage Temperature MAX6241AMJA M 2.0 5.0 Coefficient (Note 1) TCVOUT MAX6241BC_A C 2.5 5.0 ppm/°C MAX6241BE_A E 2.5 7.0 MAX6241BMJA M 2.5 8.0 +25°C 10 18 C 30 8V ≤ VIN ≤ 10V E 35 M 45 Line Regulation (Note 2) ΔVOUT / ΔVIN +25°C 2 5 ppm/V C 7 10V ≤ VIN ≤ 36V E 8 M 10 C 1 6 Sourcing: 0mA ≤ IOUT ≤ 15mA E 1 7 M 3 9 Load Regulation (Note 2) ΔVOUT / ΔIOUT C 1 6 ppm/mA Sinking: -15mA ≤ IOUT ≤ 0mA E 1 7 M 7 18 +25µC 1.9 2.9 Supply Current IIN C, E, M 3.2 mA Trim-Adjustment Range ΔVOUT Figure 1 C, E, M ±24 ±40 mV Turn-On Settling Time tON To ±0.01% of final value +25°C 8 µs 0.1Hz ≤ f ≤ 10Hz +25°C 2.4 µVp-p Output Noise Voltage (Note 3) en 10Hz ≤ f ≤ 1kHz +25°C 2.0 4.0 µVRMS Temperature Hysteresis (Note 4) +25°C 20 ppm Long-Term Stability ΔVOUT / t +25°C 20 ppm/ 1000h www.maximintegrated.com Maxim Integrated │ 4
