Datasheet ADP1611 (Analog Devices) - 5
Description20 V,1.2 MHz Step-Up DC-to-DC Switching Converter
Pages / Page20 / 5 — ADP1611. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. COMP. TOP VIEW. …
File Format / SizePDF / 763 Kb
ADP1611. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. COMP. TOP VIEW. (Not to Scale). GND
ADP1611 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS COMP TOP VIEW (Not to Scale) GND
ADP1611 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS COMP 1 8 SS FB ADP1611 2 7 RT TOP VIEW SD 3 6 IN (Not to Scale) GND 4 5 SW
04906-0-003 Figure 3. Pin Configuration
Table 3. Pin Function Descriptions Pin No. Mnemonic Description
1 COMP Compensation Input. Connect a series resistor-capacitor network from COMP to GND to compensate the regulator. 2 FB Output Voltage Feedback Input. Connect a resistive voltage divider from the output voltage to FB to set the regulator output voltage. 3 SD Shutdown Input. Drive SD low to shut down the regulator; drive SD high to turn it on. 4 GND Ground. 5 SW Switching Output. Connect the power inductor from the input voltage to SW and connect the external rectifier from SW to the output voltage to complete the step-up converter. 6 IN Main Power Supply Input. IN powers the ADP1611 internal circuitry. Connect IN to the input source voltage. Bypass IN to GND with a 10 µF or greater capacitor as close to the ADP1611 as possible. 7 RT Frequency Setting Input. RT controls the switching frequency. Connect RT to GND to program the oscillator to 700 kHz, or connect RT to IN to program it to 1.2 MHz. 8 SS Soft-Start Timing Capacitor Input. A capacitor from SS to GND brings up the output slowly at power-up. Rev. 0 | Page 5 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CURRENT-MODE PWM OPERATION FREQUENCY SELECTION SOFT START ON/OFF CONTROL SETTING THE OUTPUT VOLTAGE INDUCTOR SELECTION CHOOSING THE INPUT AND OUTPUT CAPACITORS DIODE SELECTION LOOP COMPENSATION SOFT-START CAPACITOR APPLICATION CIRCUITS STEP-UP DC-TO-DC CONVERTER WITH TRUE SHUTDOWN TFT LCD BIAS SUPPLY SEPIC POWER SUPPLY LAYOUT PROCEDURE OUTLINE DIMENSIONS ORDERING GUIDE
