Datasheet MAX6161 (Analog Devices) - 5
DescriptionPrecision, Micropower, Low-Dropout, High-Output-Current, SO-8 Voltage References
Pages / Page17 / 5 — Electrical Characteristics—MAX6166 (VOUT = 2.500V). PARAMETER. SYMBOL. …
File Format / SizePDF / 2.7 Mb
Electrical Characteristics—MAX6166 (VOUT = 2.500V). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. DYNAMIC CHARACTERISTICS
Electrical Characteristics—MAX6166 (VOUT = 2.500V) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS DYNAMIC CHARACTERISTICS
MAX6161–MAX6168 Precision, Micropower, Low-Dropout, High-Output-Current, SO-8 Voltage References
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise specified. Typical values are at TA = +25°C.) (Note 1)
MAX6166A 2.498 2.500 2.502 Output Voltage VOUT TA = +25°C V MAX6166B 2.495 2.500 2.505 Output Voltage Temperature MAX6166A 2 5 Coefficient (Note 2) TCVOUT ppm/°C MAX6166B 4 10 Dropout Voltage (Note 4) VIN - VOUT IOUT = 1mA 50 200 mV Line Regulation ΔVOUT/ ΔV VOUT + 0.2V ≤ VIN ≤ 12.6V 60 250 µV/V IN Sourcing: 0 ≤ I Load Regulation ΔVOUT/ OUT ≤ 5mA 0.5 0.9 ΔI mV/mA OUT Sinking: -2mA ≤ IOUT ≤ 0 1.6 5 Short to GND 110 OUT Short-Circuit Current ISC mA Short to IN 25 Long-Term Stability ΔVOUT/ time 1000hr at +25°C 80 ppm/ 1000hr Output Voltage Hysteresis ΔVOUT/ (Note 3) cycle 125 ppm
f = 0.1Hz to 10Hz 27 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 30 µVRMS Ripple Rejection VOUT/VIN VIN = 5V ±100mV, f = 120Hz 76 dB Turn-On Settling Time tR VOUT to 0.1% of final value, COUT = 50pF 115 µs
INPUT CHARACTERISTICS
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 100 120 µA Change in Supply Current ΔIIN/ΔVIN VOUT + 0.2V ≤ VIN ≤ 12.6V 3.2 8.0 µA/V www.maximintegrated.com Maxim Integrated │ 5
