Datasheet MAX6133 (Analog Devices) - 2
Description3ppm/°C, Low-Power, Low-Dropout Voltage Reference
Pages / Page13 / 2 — 3ppm/°C, Low-Power, Low-Dropout Voltage Reference. ABSOLUTE MAXIMUM …
File Format / SizePDF / 523 Kb
3ppm/°C, Low-Power, Low-Dropout Voltage Reference. ABSOLUTE MAXIMUM RATINGS. MAX6133
3ppm/°C, Low-Power, Low-Dropout Voltage Reference ABSOLUTE MAXIMUM RATINGS MAX6133
Voltage (with Respect to GND) Operating Temperature Range ...-40°C to +125°C IN ..-0.3V to +13V Storage Temperature Range ...-65°C to +150°C OUT..-0.3V to +6V or (VIN + 0.3V) Junction Temperature ..+150°C OUT Short Circuit to IN or GND Duration ...60s Lead Temperature (soldering, 10s) ...+300°C Continuous Power Dissipation (TA = +70°C) 8-Pin µMAX (derate 5.5mW/°C above +70°C) ...362mW 8-Pin SO (derate 5.88mW/°C above +70°C)..471mW
MAX6133
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
ELECTRICAL CHARACTERISTICS—MAX6133_25 (VOUT = 2.500V)
(VIN = 5V, CLOAD = 0.1µF, IOUT = 0, TA = TMIN to TMAX. Typical values are at TA = +25°C, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
A grade SO 2.4990 2.5000 2.5010 Output Voltage VOUT TA = +25°C B grade SO 2.4980 2.5000 2.5020 V µMAX 2.4985 2.5000 2.5015 A grade SO -0.04 +0.04 Output Voltage TA = +25°C B grade SO -0.08 +0.08 % Accuracy µMAX -0.06 +0.06 TA = -40°C to +85°C 1 3 A grade SO TA = -40°C to +125°C 4 7 Output Voltage TA = -40°C to +85°C 3 5 Temperature TCVOUT B grade SO ppm/°C TA = -40°C to +125°C 5 10 Coefficient (Note 1) TA = -40°C to +85°C 1 5 µMAX TA = -40°C to +125°C 2 7 Input Voltage Range VIN Inferred from line regulation 2.7 12.6 V Line Regulation ∆VOUT/∆VIN 2.7V ≤ VIN ≤ 12.6V 2 30 µV/V Load Regulation ∆VOUT/∆IOUT -100µA ≤ IOUT ≤ 15mA 0.003 0.05 mV/mA Dropout Voltage ∆VOUT = 0.1%, IOUT = 1mA 0.02 0.2 V V (Note 2) DO ∆VOUT = 0.1%, IOUT = 10mA 0.2 0.4 Quiescent Supply TA = +25°C 40 60 I µA Current IN TA = -40°C to +125°C 85 Output Short-Circuit Short to GND: VOUT = 0V 90 ISC mA Current Short to VIN: VOUT = VIN -2 0.1Hz ≤ f ≤ 10Hz 16 µVP-P Output Voltage Noise en 10Hz ≤ f ≤ 1kHz 12 µVRMS Turn-On Settling Time tON VOUT settles to ±0.01% of final value 500 µs Thermal Hysteresis 120 ppm (Note 3) SO 40 Long-Term Stability ∆t = 1000 hours ppm µMAX 145
2 _______________________________________________________________________________________
