Datasheet MAX6133 (Analog Devices) - 6
Description | 3ppm/°C, Low-Power, Low-Dropout Voltage Reference |
Pages / Page | 13 / 6 — 3ppm/°C, Low-Power, Low-Dropout Voltage Reference. Typical Operating … |
File Format / Size | PDF / 523 Kb |
3ppm/°C, Low-Power, Low-Dropout Voltage Reference. Typical Operating Characteristics. OUTPUT VOLTAGE vs. TEMPERATURE
3ppm/°C, Low-Power, Low-Dropout Voltage Reference Typical Operating Characteristics
(VIN = 5V, IOUT = 0, TA = +25°C, unless otherwise noted.) (Note 4)
OUTPUT VOLTAGE vs. TEMPERATURE OUTPUT VOLTAGE vs. TEMPERATURE LOAD REGULATION (VOUT = 2.5V) (VOUT = 5V) (VOUT = 2.5V)
2.5010 5.0010 2.5040 3 TYPICAL UNITS 3 TYPICAL UNITS 2.5008 2.5035 VIN = 5.5V
MAX6133
5.0005 MAX6133 toc01 MAX6133 toc02 MAX6133 toc03 2.5030 TA = +125°C 2.5006 2.5025 2.5004 5.0000 2.5020 TA = +85°C 2.5002 4.9995 2.5015 2.5000 TA = +25°C 2.5010 TA = -40°C 2.4998 4.9990 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 2.5005 2.4996 2.5000 4.9985 2.4994 2.4995 2.4992 4.9980 2.4990 -40 -25 -10 5 20 35 50 65 80 95 110 125 -40 -25 -10 5 20 35 50 65 80 95 110 125 0 2 4 6 8 10 12 14 16 18 20 TEMPERATURE (°C) TEMPERATURE (°C) OUTPUT CURRENT (mA)
LOAD REGULATION DROPOUT VOLTAGE vs. OUTPUT CURRENT DROPOUT VOLTAGE vs. OUTPUT CURRENT (VOUT = 5V) (VOUT = 2.5V) (VOUT = 5V)
5.0020 700 600 VIN = 5.5V V 550 IN = 5.5V 5.0015 600 500 TA = +125°C MAX6133 toc04 MAX6133 toc05 MAX6133 toc06 5.0010 450 500 TA = +85°C TA = +25°C 400 5.0005 TA = +125°C 350 400 TA = +85°C 5.0000 300 300 TA = +125°C 250 TA = +25°C 4.9995 TA = +25°C 200 OUTPUT VOLTAGE (V) DROPOUT VOLTAGE (mV) 200 DROPOUT VOLTAGE (mV) 4.9990 150 TA = -40°C 100 100 4.9985 T T T A = +85°C A = -40°C A = -40°C 50 4.9980 0 0 0 2 4 6 8 10 12 14 16 18 20 0 2 4 6 8 10 12 14 16 18 20 0 2 4 6 8 10 12 14 16 18 20 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA)
POWER-SUPPLY REJECTION RATIO POWER-SUPPLY REJECTION RATIO SUPPLY CURRENT vs. INPUT VOLTAGE vs. FREQUENCY (V vs. FREQUENCY (V OUT = 2.5V) OUT = 5V) (VOUT = 2.5V)
0 150 0 VIN = 5.5V 135 -20 -20 MAX6133 toc07 MAX6133 toc08 MAX6133 toc09 120 µA) 105 -40 -40 90 -60 75 T -60 A = +125°C T PSRR (dB) A = +85°C PSRR (dB) 60 -80 -80 SUPPLY CURRENT ( 45 30 -100 -100 15 TA = +25°C TA = -40°C -120 -120 0 0.0001 0.001 0.01 0.1 1 10 100 1000 0.0001 0.001 0.01 0.1 1 10 100 1000 0 1 2 3 4 5 6 7 8 9 10 11 12 13 FREQUENCY (kHz) FREQUENCY (kHz) INPUT VOLTAGE (V)
6 _______________________________________________________________________________________
