Datasheet MAX6226 (Analog Devices) - 5
DescriptionUltra-High-Precision, Ultra-Low-Noise, Series Voltage Reference
Pages / Page16 / 5 — MAX6226. Electrical Characteristics—MAX6226_50 (VOUT = 5.000V). …
MAX6226. Electrical Characteristics—MAX6226_50 (VOUT = 5.000V). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. OUTPUT
MAX6226 Electrical Characteristics—MAX6226_50 (VOUT = 5.000V) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
MAX6226
(VIN = 5.5V, CLOAD = 0.1μF, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C . (Note 1))
Output Voltage VOUT TA = +25°C 5.000 V Output Voltage Accuracy Referred to VOUT, TA = +25°C A grade -0.02 +0.02 % Output Voltage Temperature Coefficient (Note 2) TCVOUT TA = -40°C to +125°C A grade 1 3 ppm/°C T Line Regulation ΔVOUT/ A = +25°C 9 40 ΔV 5.2V ≤ VIN ≤ 12.6V µV/V IN TA = -40°C to +125°C 80 Sourcing: 0 ≤ I Load Regulation ΔVOUT/ OUT ≤ 10mA 5 50 ΔI µV/mA OUT Sinking: -10mA ≤ IOUT ≤ 0 50 250 I Dropout Voltage (Note 3) V OUT = 5mA 0.06 0.2 IN - VOUT ΔVOUT = 0.1% V IOUT = 10mA 0.12 0.4 Short to GND 160 OUT Short-Circuit Current ISC mA Short to IN 20 Thermal Hysteresis (Note 4) ΔVOUT/ cycle 5 ppm
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 2.85 µVP-P Noise Voltage eOUT f = 1kHz, CNR = 0 145 nV/√Hz f = 1kHz, CNR = 0.1µF 95 C Turn-On Settling Time t To VOUT = 0.01% of NR = 0 2 R final value ms CNR = 0.1µF 20 Capacitive-Load Stability Range CLOAD No sustained oscillations 0.1 to 10 µF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test 5.2 12.6 V T Quiescent Supply Current I A = +25°C 380 580 IN µA TA = -40°C to +125°C 725
Note 1:
All devices are 100% production tested at TA = +25°C and are guaranteed by design for TA = TMIN to TMAX, as specified.
Note 2:
Temperature coefficient is measured by the “box” method, i.e., the maximum ΔVOUT/VOUT is divided by the maximum ΔT.
Note 3:
Dropout voltage is defined as the minimum differential voltage (VIN - VOUT) at which VOUT decreases by 0.1% from its original value at VIN = 5.0V for VOUT = 2.5V and VOUT = 3.3V, and VIN = 5.5V for VOUT = 5.0V).
Note 4:
Thermal hysteresis is defined as the change in +25°C output voltage before and after cycling the device from TMAX to TMIN. www.analog.com Analog Devices │ 5
