Datasheet 74HCT14D (Nexperia)
ManufacturerNexperia
DescriptionHex inverting Schmitt trigger
Pages / Page16 / 1 — 74HC14; 74HCT14. Hex inverting Schmitt trigger. Rev. 10 — 29 February …
File Format / SizePDF / 276 Kb
74HC14; 74HCT14. Hex inverting Schmitt trigger. Rev. 10 — 29 February 2024. Product data sheet. 1. General description
Datasheet 74HCT14D Nexperia
74HC14; 74HCT14 Hex inverting Schmitt trigger Rev. 10 — 29 February 2024 Product data sheet 1. General description
The 74HC14; 74HCT14 is a hex inverter with Schmitt-trigger inputs. This device features reduced input threshold levels to allow interfacing to TTL logic levels. Inputs also include clamp diodes, this enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals.
2. Features and benefits
• Wide supply voltage range from 2.0 to 6.0 V • CMOS low power dissipation • High noise immunity • Unlimited input rise and fall times • Latch-up performance exceeds 100 mA per JESD 78 Class II Level B • Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) • ESD protection: • HBM: ANSI/ESDA/JEDEC JS-001 class 2 exceeds 2000 V • CDM: ANSI/ESDA/JEDEC JS-002 class C3 exceeds 1000 V • Multiple package options • Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Applications
• Wave and pulse shapers • Astable multivibrators • Monostable multivibrators
4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version
74HC14D -40 °C to +125 °C SO14 plastic small outline package; 14 leads; SOT108-1 74HCT14D body width 3.9 mm 74HC14PW -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; SOT402-1 74HCT14PW body width 4.4 mm 74HC14BQ -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced SOT762-1 74HCT14BQ very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm Document Outline 1. General description 2. Features and benefits 3. Applications 4. Ordering information 5. Functional diagram 6. Pinning information 6.1. Pinning 6.2. Pin description 7. Functional description 8. Limiting values 9. Recommended operating conditions 10. Static characteristics 11. Dynamic characteristics 11.1. Waveforms and test circuit 12. Transfer characteristics 12.1. Transfer characteristics waveforms 13. Application information 14. Package outline 15. Abbreviations 16. Revision history 17. Legal information Contents
