Datasheet VLMS1300 (Vishay) - 4
ManufacturerVishay
DescriptionHighbright 0603 ChipLED
Pages / Page13 / 4 — VLMS1300, VLMO1300, VLMY130., VLMG1300, VLMTG1300, VLMB13.. LUMINOUS …
File Format / SizePDF / 264 Kb
VLMS1300, VLMO1300, VLMY130., VLMG1300, VLMTG1300, VLMB13.. LUMINOUS INTENSITY CLASSIFICATION. COLOR CLASSIFICATION
VLMS1300, VLMO1300, VLMY130., VLMG1300, VLMTG1300, VLMB13. LUMINOUS INTENSITY CLASSIFICATION COLOR CLASSIFICATION
LUMINOUS INTENSITY CLASSIFICATION COLOR CLASSIFICATION LUMINOUS INTENSITY (mcd) DOMINANT WAVELENGTH GROUP MIN. MAX. COLOR GROUP (nm)
M 18 28
MIN. MAX.
N 28 45 H 584.5 587.5 P 45 71 J 587.5 589.5 Q 71 112 Yellow K 589.5 592 R 112 180 L 592 594.5 S 180 280 M 594.5 597 T 280 450 C 567.5 570.5 Yellow green D 570.5 573.5
Note
• Luminous intensity is tested at a current pulse duration of 25 ms E 573.5 576.5 and an accuracy of ± 15 %. AP 520 525 • The above type numbers represent the order groups which True green AQ 525 530 include only a few brightness groups. Only one group will be shipped on each reel (there will be no mixing of two groups on AR 530 535 each reel).In order to ensure availability, single brightness AC 465 470 groups will not be orderable. Blue AD 470 475 • In a similar manner for colors where wavelength groups are measured and binned, single wavelength groups will be shipped
Note
in any one reel. • Wavelengths are tested at a current pulse duration of 25 ms and • In order to ensure availability, single wavelength groups will not an accuracy of ± 1 nm be orderable.
FORWARD VOLTAGE CLASSIFICATION FORWARD VOLTAGE (V) COLOR GROUP MIN. MAX.
F2 1.8 2.1 Yellow F3 2.1 2.4 4 1.9 2 5 2 2.1 Yellow green 6 2.1 2.2 7 2.2 2.3 8 2.3 2.4 D7 2.8 3 D8 3 3.2 True green D9 3.2 3.4 D10 3.4 3.6 D7 2.8 3 D8 3 3.2 Blue D9 3.2 3.4 D10 3.4 3.6 D11 3.6 3.8
Note
• Forward voltage is measured with a tolerance of ± 0.1 V Rev. 1.6, 30-Mar-2023
4
Document Number: 82437 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
