Datasheet MAX6325 (Analog Devices) - 5
Description1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V Voltage References
Pages / Page11 / 5 — 1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V. Voltage References
File Format / SizePDF / 556 Kb
MAX6325/MAX6341/MAX6350 MAX6325/MAX6341/MAX6350
1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V Voltage References __________________________________________Typical Operating Characteristics
(VIN = +10V, IOUT = 0mA, TA = +25°C, unless otherwise noted.)
MAX6350 MAX6341 MAX6325 NORMALIZED OUTPUT VOLTAGE NORMALIZED OUTPUT VOLTAGE NORMALIZED OUTPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
MAX6325 -01 MAX6325 -02 2.0 400 1.5 MAX6325 03 375 0.7 280 0.6 240 1.5 300 1.0 250 0.5 200 1.0 200 0.4 160 0.3 120 0.5 125 0.5 100 (mV) (ppm) (mV) (ppm) (mV) 0.2 80 (ppm) OUT OUT OUT OUT OUT 0.1 40 OUT ∆V 0 0 ∆V ∆V 0 0 ∆V ∆V ∆V 0 0 -0.5 -100 -0.1 -40 -0.5 -125 -0.2 -80 -1.0 -200 -0.3 -120 -1.5 -300 -1.0 -250 -0.4 -160 -55 -35 -15 5 25 45 65 85 105 125 -55 -35 -15 5 25 45 65 85 105 125 -55 -35 -15 5 25 45 65 85 105 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
MAX6325 MAX6341 CHANGE IN OUTPUT VOLTAGE CHANGE IN OUTPUT VOLTAGE CHANGE IN OUTPUT VOLTAGE vs. INPUT VOLTAGE vs. OUTPUT CURRENT vs. OUTPUT CURRENT
200 300 60 150 TA = +85°C MAX6325-06 50 MAX6325-05 MAX6325-04 200 100 40 50 100 30 µV) µV) TA = +25°C ( 0 TA = -40°C ( (ppm) TA = +25°C 0 20 OUT OUT OUT -50 ∆V ∆V ∆V 10 -100 -100 T 0 A = -40°C -150 -200 TA = +85°C -10 -200 -20 -250 -300 0 5 10 15 20 25 30 35 40 -40 -30 -20 -10 0 10 20 30 40 -40 -30 -20 -10 0 10 20 30 40 V I I IN (V) OUT (mA) OUT (mA)
MAX6350 CHANGE IN OUTPUT VOLTAGE vs. OUTPUT CURRENT SUPPLY CURRENT vs. SUPPLY VOLTAGE SUPPLY CURRENT vs. TEMPERATURE
300 3.0 3.5 2.8 200 MAX6325-07 MAX6325-08 MAX6325-09 2.6 3.0 MAX6350 100 2.4 MAX6341 µV) MAX6325 2.5 MAX6350 0 2.2 ( TA = -40°C TA = +85°C 2.0 MAX6341 OUT -100 ∆V 1.8 2.0 -200 1.6 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 1.4 1.5 -300 TA = +25°C MAX6325 1.2 -400 1.0 1.0 -40 -30 -20 -10 0 10 20 30 40 0 5 10 15 20 25 30 35 40 -55 -35 -15 5 25 45 65 85 105 125 IOUT (mA) SUPPLY VOLTAGE (V) TEMPERATURE (°C) Maxim Integrated 5
