Datasheet MMSZ (Vishay)
ManufacturerVishay
DescriptionSmall Signal Zener Diodes
Pages / Page6 / 1 — MMSZ5225 to MMSZ5267. Small Signal Zener Diodes. FEATURES. MARKING. X.Y. …
File Format / SizePDF / 144 Kb
MMSZ5225 to MMSZ5267. Small Signal Zener Diodes. FEATURES. MARKING. X.Y. LINKS TO ADDITIONAL RESOURCES. D 3. 3 D. 3D Models. Models
Datasheet MMSZ Vishay
Small Signal Zener Diodes FEATURES
• Silicon planar Zener diodes Available • Standard Zener voltage tolerance is ± 5 % 1 2 with a “B” suffix (e.g.: MMSZ5225B), suffix “C” is ± 2 % tolerance • AEC-Q101 qualified available
MARKING
(example only) • ESD capability according to AEC-Q101: Human body model > 8 kV Machine model > 800 V X.Y = type code • Base P/N-E3 - RoHS-compliant, commercial grade
X.Y Y4
Y4 = date code • Base P/N-HE3_A - RoHS-compliant, AEC-Q101 qualified Cathode mark 23210 • Material categorization: for definitions of compliance
please see www.vishay.com/doc?99912
D 3 3 D 3D Models Models PRIMARY CHARACTERISTICS PARAMETER VALUE UNIT
VZ range nom. 3.0 to 75 V Test current IZT 1.7 to 20 mA VZ specification Thermal equilibrium Circuit configuration Single
ORDERING INFORMATION DEVICE ZENER AEC-Q101 TAPED UNITS MINIMUM NAME ORDERING CODE VOLTAGE ORDER TOLERANCE QUALIFIED PER REEL QUANTITY
MMSZ5225B-E3-08 to MMSZ5267B-E3-08 5 % no MMSZ5225C-E3-08 to MMSZ5267C-E3-08 2 % no 3000 15 000/box MMSZ5225B-HE3_A-08 to MMSZ5267B-HE3_A-08 5 % yes (8 mm tape on 7" reel) MMSZ5225 MMSZ5225C-HE3_A-08 to MMSZ5267C-HE3_A-08 2 % yes to MMSZ5267 MMSZ5225B-E3-18 to MMSZ5267B-E3-18 5 % no MMSZ5225C-E3-18 to MMSZ5267C-E3-18 2 % no 10 000 10 000/box MMSZ5225B-HE3_A-18 to MMSZ5267B-HE3_A-18 5 % yes (8 mm tape on 13" reel) MMSZ5225C-HE3_A-18 to MMSZ5267C-HE3_A-18 2 % yes
PACKAGE PACKAGE NAME WEIGHT MOLDING COMPOUND FLAMMABILITY RATING MOISTURE SENSITIVITY LEVEL SOLDERING CONDITIONS
SOD-123 10.6 mg UL 94 V-0 MSL level 1 (according J-STD-020) Peak temperature max. 260 °C
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL VALUE UNIT
RthJL = 250 K/W Ptot 500 mW Power dissipation On FR-4 board with recommended soldering footprint Ptot 300 mW Thermal resistance junction to lead RthJL 250 K/W According to JEDEC® 51-3 on FR-4 board with Thermal resistance junction to ambient R recommended soldering footprint thJA 420 K/W Junction temperature Tj 150 Storage temperature range Tstg -65 to +150 °C Operating temperature range Top -55 to +150 Rev. 1.1, 17-Jul-2023
1
Document Number: 86344 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
