Datasheet SG-8002CE (Epson) - 3
ManufacturerEpson
DescriptionProgrammable Crystal Oscillator with CMOS Output 1 Mhz To 125 Mhz in Ceramic SON 4pin 3.2x2.5x1.05 Mm Package (4-SMD, No Lead)
Pages / Page6 / 3 — External dimensions and Recommended footprint (Continued). SG-8002JA. SOJ …
File Format / SizePDF / 700 Kb
External dimensions and Recommended footprint (Continued). SG-8002JA. SOJ 4pin 14.0x9.8x4.7 mm. EPSON. 100.0000 C. 2PH 9357B
External dimensions and Recommended footprint (Continued) SG-8002JA SOJ 4pin 14.0x9.8x4.7 mm EPSON 100.0000 C 2PH 9357B
SG-8002CE
Crystal oscillator
(Unit:mm)
Package and pin compatible with SG-615. 14.0 Max. #4 #3 1.3
EPSON
x. 5
100.0000 C
6 Ma .0 . 3 8 8.9
2PH 9357B
.8 8 #1 #2 .x Ma 5 7 2 . 5.08 4 0 0.51 7.62 5.08 0.25Min.
SG-8002DC DIP half size
#8 #5
EPSON 100.0000 C
6.6
2PH 9357B
#1 13.7 Max. #4 . 7.62 ax M 5.3 n. 0.25 0.2Min. Mi 0.51 90~105 7.62 2.54 Note. OE Pin (PT, PH, PC) Pin map Pin map: SG-8002DC OE Pin = "H" or "open": Specified frequency output. Pin Connection Pin Connection OE Pin = "L": Output is high impedance. 1 OE or ST 1 OE or ST 2 GND 4 GND ST Pin (ST, SH, SC) 3 OUT 5 OUT ST Pin = "H" or "open": Specified frequency output. 4 VCC 8 VCC ST Pin = "L": Output is low level (weak pull - down), oscillation stops. To maintain stable operation, provide a 0.01uF to 0.1uF by-pass capacitor at a location as near as possible to the power source terminal of the crys- tal product (between Vcc - GND).
Products number
(Please contact us for each product.) SG-8002CE: Q3321CExxxxxx00 SG-8002JC: Q3307JCx2xxxx00 SG-8002CA: Q3309CAx0xxxx00 SG-8002DC: Q3204DCx2xxxx00 SG-8002JA: Q3306JAx2xxxx00 Document Outline SG-8002series_E187.pdf QMEMS_E152
