Datasheet SGL41 (Vishay) - 3
ManufacturerVishay
DescriptionSurface Mount Schottky Barrier Rectifier
Pages / Page5 / 3 — RATINGS AND CHARACTERISTICS CURVES
File Format / SizePDF / 86 Kb
BYM13-xx, SGL41-xx www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted) 1.0 100 Resistive or SGL41-20 to SGL41-40 Inductive Load SGL41-50 and SGL41-60 0.75 10 SGL41-20 to SGL41-40 T = 125 °C J 1 ard Current (A) 0.50 erse Current (mA) orw SGL41-50 and SGL41-60 v 0.1 T = 75 °C age F J 0.25 er v PCB Mounted on A 0.24" x 0.24" (6.0 mm x 6.0 mm) 0.01 Copper Land Areas T = 25 °C J 0 Instantaneous Re 0 25 50 75 100 125 150 175 0.001 Terminal Temperature (°C) 0 20 40 60 80 100 Percent of Rated Peak Reverse Voltage (%) Fig. 1 - Forward Current Derating Curve Fig. 4 - Typical Reverse Characteristics 30 At Rated T 1000 d 8.3 ms Single Half Sine-Wave T = 25 °C J 25 f = 1.0 MHz V = 50 mV sig p-p 20 tance (pF) 100 15 ard Surge Current (A) orw 10 eak F unction Capaci P J SGL41-20 to SGL41-40 5 SGL41-50 and SGL41-60 1 10 100 10 Number of Cycles at 60 Hz 0.1 1 10 100 Reverse Voltage (V) Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Current Fig. 5 - Typical Junction Capacitance 100 T = 125 °C J 10 T = 150 °C J Pulse Width = 300 µs 1 % Duty Cycle ard Current (A) 1 orw T = 25 °C J 0.1 SGL41-20 to SGL41-40 Instantaneous F SGL41-50 and SGL41-60 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 Instantaneous Forward Voltage (V) Fig. 3 - Typical Instantaneous Forward Characteristics Reivision: 01-Sep-2021 3 Document Number: 88548 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
