Datasheet MAX6069 (Analog Devices) - 2
Description1μA WLP Precision Shunt Voltage Reference
Pages / Page9 / 2 — MAX6069. Absolute Maximum Ratings. Package Information. WLP. 21-100139. …
File Format / SizePDF / 645 Kb
MAX6069. Absolute Maximum Ratings. Package Information. WLP. 21-100139. Application Note 1891
MAX6069 Absolute Maximum Ratings Package Information WLP 21-100139 Application Note 1891
MAX6069
1μA Ultra-Tiny Shunt Voltage Reference
Operating Current (OUT to GND) ..20mA Operating Temperature Range ... -40°C to +125°C Forward Current (GND to OUT) ...20mA Storage Temperature Range .. -65°C to +150°C Continuous Power Dissipation (Multilayer Board; Junction Temperature ..+150°C derate 9.75mW/°C above +70°C) ..780mW Soldering Temperature (reflow) ...+260°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Package Code W40D1+1 Outline Number
21-100139
Land Pattern Number Refer to
Application Note 1891 Thermal Resistance, Four-Layer Board:
Junction-to-Ambient (θJA) 102.59°C/W Junction-to-Case (θJC) N/A For the latest package outline information and land patterns (footprints), go to
www.maximintegrated.com/packages
. Note that a “+”, “#”, or “-” in the package code indicates RoHS status only. Package drawings may show a different suffix character, but the drawing pertains to the package regardless of RoHS status. Package thermal resistances were obtained using the method described in JEDEC specification JESD51-7, using a four-layer board. For detailed information on package thermal considerations, refer to
www.maximintegrated.com/thermal-tutorial
Electrical Characteristics
(TA=-40°C to +125°C, unless otherwise noted., Typical values are at TA = +25°C. (Note 1))
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS MAX6069A (1.250V)
MAX6069AA (0.2%) 1.2475 1.2500 1.2525 Reverse Breakdown Voltage V TA = +25°C, R I V R = 1.2µA MAX6069AB (0.5%) 1.2438 1.2500 1.2563 Minimum Operating Current IRMIN VR change < 0.2% from VR at IR = 1.2μA 0.5 1.0 µA Reverse Breakdown Change IR = 1.2μA to 200μA 1 with Current mV IR = 200μA to 2mA 2.0 Reverse Dynamic Impedance IR = 1.2μA to 2mA (Note 2) 1.5 Ω Low-Frequency Noise IR = 1.2μA, f = 0.1Hz to 10Hz 30 µVp-p www.analog.com Analog Devices │ 2
