Datasheet MAX6069 (Analog Devices) - 4
Description1μA WLP Precision Shunt Voltage Reference
Pages / Page9 / 4 — MAX6069. Electrical Characteristics (continued). PARAMETER. SYMBOL. …
File Format / SizePDF / 645 Kb
MAX6069. Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. MAX6069D (3.00V). Note 1:. Note 2:
MAX6069 Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS MAX6069D (3.00V) Note 1: Note 2:
MAX6069
1μA Ultra-Tiny Shunt Voltage Reference
(TA=-40°C to +125°C, unless otherwise noted., Typical values are at TA = +25°C. (Note 1))
Low-Frequency Noise IR = 1.2μA, f = 0.1Hz to 10Hz 60 µVp-p IR = 1.2µA, TA = -40°C to +85°C 20 Temperature Coefficient MAX6069CA TA = -40°C to +125°C 25 (Note 3) TC ppm/°C IR = 1.2µA, TA = -40°C to +85°C 50 MAX6069CB TA = -40°C to +125°C 75 Long-Term Drift 1000h at TA = +25°C 150 ppm Thermal Hysteresis (Note 4) 200 ppm
MAX6069D (3.00V)
MAX6069DA (0.2%) 2.9940 3.0000 3.0060 Reverse Breakdown Voltage V TA = +25°C, R I V R = 1.2µA MAX6069DB (0.5%) 2.9850 3.0000 3.0150 Minimum Operating Current IRMIN VR change < 0.2% from VR at IR = 1.2μA 0.5 1.0 µA Reverse Breakdown IR = 1.2μA to 200μA 1.7 Change with Current mV IR = 200μA to 2mA 2.7 Reverse Dynamic Impedance IR = 1.2μA to 2mA (Note 2) 2.2 Ω Low-Frequency Noise IR = 1.2μA, f = 0.1Hz to 10Hz 75 µVp-p IR = 1.2µA, TA = -40°C to +85°C 20 Temperature Coefficient MAX6069DA TA = -40°C to +125°C 25 (Note 3) TC ppm/°C IR = 1.2µA, TA = -40°C to +85°C 50 MAX6069DB TA = -40°C to +125°C 75 Long-Term Drift 1000h at TA = +25°C 150 ppm Thermal Hysteresis (Note 4) 200 ppm
Note 1:
All units are 100% production tested at TA = +25°C and are guaranteed by design and characterization for TA = TMIN to TMAX, as specified.
Note 2:
This parameter is guaranteed by the “reverse breakdown change with current” test.
Note 3:
TC is measured by the “box” method; i.e., (VMAX - VMIN)/(TMAX - TMIN).
Note 4:
Thermal hysteresis is defined as the change in the +25°C output voltage after cycling a unit from TMIN to TMAX. www.analog.com Analog Devices │ 4
