Datasheet MAX6069 (Analog Devices) - 5
Description | 1μA WLP Precision Shunt Voltage Reference |
Pages / Page | 9 / 5 — MAX6069. Typical Operating Characteristics. VOUT vs. CURRENT. TEMPERATURE … |
File Format / Size | PDF / 645 Kb |
MAX6069. Typical Operating Characteristics. VOUT vs. CURRENT. TEMPERATURE DRIFT (MAX6069CA). (MAX6069CA). MAX6069CA PEAK-PEAK
MAX6069
1μA Ultra-Tiny Shunt Voltage Reference
(TA = +25°C, unless otherwise noted.)
VOUT vs. CURRENT TEMPERATURE DRIFT (MAX6069CA) (MAX6069CA)
toc2 1 toc1 10 9 0 V) V) 8 -1 7 TA = -40°C -2 HANGE (m 6 -3 5 TA = +125°C OLTAGE CHANGE (m 4 -4 3 TA = +85°C -5 2 REVERSE V REVERSE-VOLTAGE C TA = +25°C -6 1 -7 0 -50 -25 0 25 50 75 100 125 0.001 0.01 0.1 1 10 TEMPERATURE (°C) REVERSE CURRENT (mA)
MAX6069CA PEAK-PEAK MAX6069CA STARTUP OUTPUT VOLTAGE NOISE (C (0.1Hz to 10Hz) L = 0.01µF)
toc3 toc4 1.2µA IR 0 20µV/div VOUT (1V/div) 4ms/div 4s/div
MAX6069CA REVERSE DYNAMIC IMPEDANCE OUTPUT IMPEDANCE vs. FREQUENCY vs. TEMPERATURE (MAX6069CA)
toc5 0.3 toc6 VOUT = 2.5V, I ) R = 6µA, IR-AC = ±2.5µA 100 CL = 0.01µF 0.2 PEDANCE (Ω C IC IM L = 1µF IMPEDANCE (Ω) 10 0.1 REVERSE DYNAM 1 0 0.1 1 10 100 1000 -50 -25 0 25 50 75 100 125 FREQUENCY (kHz) TEMPERATURE (°C) www.analog.com Analog Devices │ 5
