Datasheet MAX6520 (Analog Devices) - 2
Description50ppm/°C, SOT23, 3-Terminal, 1.2V Voltage Reference
Pages / Page6 / 2 — 50ppm/°C, SOT23, 3-Terminal,. 1.2V Voltage Reference. ABSOLUTE MAXIMUM …
File Format / SizePDF / 331 Kb
50ppm/°C, SOT23, 3-Terminal,. 1.2V Voltage Reference. ABSOLUTE MAXIMUM RATINGS. MAX6520. DC ELECTRICAL CHARACTERISTICS. PARAMETER
50ppm/°C, SOT23, 3-Terminal, 1.2V Voltage Reference ABSOLUTE MAXIMUM RATINGS MAX6520 DC ELECTRICAL CHARACTERISTICS PARAMETER
Supply Voltage (VIN) ..-0.3V to +12V Operating Temperature Range ...-40°C to +85°C VOUT ..-0.3V to (VIN + 0.3V) Storage Temperature Range ...-65°C to +160°C Output Short-Circuit Duration ..Continuous to Either Supply Lead Temperature (soldering, 10s) ...+300°C Continuous Power Dissipation (TA = +70°C) SOT23 (derate 4mW/°C above +70°C) ...320mW Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to
MAX6520
absolute maximum rating conditions for extended periods may affect device reliability.
(VIN = 2.4V, ILOAD = 0mA, TA = +25°C, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
TA = +25°C 1.188 1.200 1.212 V Output Voltage VOUT MAX6520EUR TA = TMIN to TMAX 1.176 1.224 V Output Voltage Temperature TCVOUT MAX6520EUR, TA = TMIN to TMAX 25 50 ppm/°C Coefficient 0.1Hz to 10Hz 10 Output Voltage Noise en µVp-p 10Hz to 10kHz 400 Line Regulation VOUT/VIN VIN = 2.4V to 11V, TA = TMIN to TMAX (Note 1) 2 30 µV/V Load Regulation VOUT/IOUT ILOAD = -50µA to 400µA (Note 1) 0.1 1 µV/µA TA = +25°C 50 58 Quiescent Supply Current IQ µA TA = TMIN to TMAX (Note 1) 70 Change in Supply Current IQ/VIN VIN = 2.4V to 11V 1.5 5 µA/V vs. Input Voltage VOUT shorted to GND 4.3 mA Short-Circuit Output Current ISC VOUT shorted to VIN 400 µA
Note 1:
Production testing done at TA = +25°C, over temperature limits guaranteed by parametric correlation data.
__________________________________________Typical Operating Characteristics
(VIN = 3V, ILOAD = 0mA, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT SUPPLY CURRENT SUPPLY CURRENT vs. INPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
80 75 75 MAX6520 TOC-01 MAX6520 TOC-02 70 MAX6520 TOC-02 70 µA) µA) µA) 70 VIN = 9V VIN = 9V 65 65 60 VIN = 5V 60 VIN = 5V 60 VIN = 3V V SUPPLY CURRENT ( SUPPLY CURRENT ( SUPPLY CURRENT ( IN = 3V 55 55 50 50 50 2 3 4 5 6 7 8 9 10 11 -50 -25 0 25 50 75 100 -50 -25 0 25 50 75 100 INPUT VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C)
2 _______________________________________________________________________________________
