Datasheet TCST1230 (Vishay) - 2
ManufacturerVishay
DescriptionTransmissive Optical Sensor With Phototransistor Output
Pages / Page6 / 2 — TCST1230. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 103 Kb
TCST1230. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. OUTPUT (DETECTOR). BASIC CHARACTERISTICS. MIN. TYP. MAX
TCST1230 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL VALUE UNIT OUTPUT (DETECTOR) BASIC CHARACTERISTICS MIN TYP MAX
TCST1230
(Tamb = 25 °C, unless otherwise specified)
Collector emitter voltage VCEO 70 V Emitter collector voltage VECO 7 V Collector current IC 100 mA Power dissipation Tamb ≤ 25 °C PV 150 mW Junction temperature Tj 100 °C
400 300 Coupled device 200 Phototransistor IR-diode 100 P - Power Dissipation (mW) 0 0 30 60 90 120 150 95 11088 T amb - Ambient Temperature (°C) Fig. 1 - Power Dissipation Limit vs. Ambient Temperature
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT COUPLER
Collector current VCE = 10 V, IF = 20 mA IC 0.5 14 mA Collector emitter saturation I voltage F = 20 mA, IC = 0.2 mA VCEsat 0.4 V
INPUT (EMITTER)
Forward voltage IF = 60 mA VF 1.25 1.5 V Junction capacitance VR = 0 V, f = 1 MHz Cj 50 pF
OUTPUT (DETECTOR)
Collector emitter voltage IC = 1 mA VCEO 70 V Emitter collector voltage IE = 10 μA VECO 7 V Collector dark current VCE = 25 V, IF = 0 A, E = 0 lx ICEO 10 100 nA
SWITCHING CHARACTERISTICS
I Turn-on time C = 1 mA, VCE = 5 V, t R on 15 μs L = 100 Ω (see figure 2) I Turn-off time C = 1 mA, VCE = 5 V, t R off 10 μs L = 100 Ω (see figure 2) Rev. 2.0, 21-Sep-12
2
Document Number: 83765 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
