DG2001E www.vishay.com Vishay Siliconix Powered-off Protection, 0.85, 1.8 V to 5.5 V,SPDT Analog Switch (2:1 Multiplexer)DESCRIPTIONFEATURES The DG2001E is a high performance single-pole, • Low switch on-resistance (0.85 ) double-throw (SPDT) analog switch designed for 1.8 V to • 1.8 V to 5.5 V single supply operation 5.5 V operation with a single power rail. • Isolation in powered-off mode Fabricated with high density CMOS technology, the device achieves low on resistance of 0.85 at a 5 V power supply, • Guaranteed 1.8 V logic high low power consumption, and fast switching speeds. • Control logic inputs can go over V+ The DG2001E can handle both analog and digital signals • Low charge injection (8 pC) and permits signals with amplitudes of up to V+ to be transmitted in either direction. Its control logic inputs can go • Break before make switching over V+ up to 5.5 V. The control logic input high threshold is • Latch-up performance exceeds 300 mA per JESD 78 guaranteed as low as 1.8 V over the power supply range up • ESD tested to 5.5 V. It features break before make switching - 7000 V human body model (JS-001) performance. - 1000 V charge device model (JS-002) A powered-off protection circuit is built into the switch to • Material categorization: for definitions of compliance prevent an abnormal current flow from COM pin to V+ during please see www.vishay.com/doc?99912 the power-down condition. Each output pin can withstand greater than 7 kV (human body model). APPLICATIONS Operation temperature is specified from -40 °C to +85 °C. The DG2001E is available in TSOP-6 package. • Consumer and computing • Portable instrumentation • Medical equipment • Battery operated systems FUNCTIONAL BLOCK DIAGRAM AND PIN CONFIGURATION TSOP-6 IN 1 6 NO (source ) 1 H1XXX V+ 2 5 COM Pin 1 GND 3 4 NC (source ) 2 Device marking: H1XXX XXX = date / lot traceability code Top view Device marking: H1 TRUTH TABLEORDERING INFORMATIONLOGICNCNOTEMP RANGEPACKAGEPART NUMBER 0 On Off -40 °C to +85 °C TSOP-6 DG2001EDV-T1-GE3 1 Off On S18-0426-Rev. B, 23-Apr-18 1 Document Number: 76471 For technical questions, contact: analogswitchtechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
