Datasheet DG20001E (Vishay) - 6
ManufacturerVishay
DescriptionPowered-off Protection, 0.85 , 1.8 V to 5.5 V, SPDT Analog Switch (2:1 Multiplexer)
Pages / Page12 / 6 — DG2001E. TYPICAL CHARACTERISTICS. ICOM(ON), VCOM = 4.5 V. NO/NC(OFF), …
File Format / SizePDF / 217 Kb
DG2001E. TYPICAL CHARACTERISTICS. ICOM(ON), VCOM = 4.5 V. NO/NC(OFF), VCOM = 1 V, VNO/NC = 4.5 V
DG2001E TYPICAL CHARACTERISTICS ICOM(ON), VCOM = 4.5 V NO/NC(OFF), VCOM = 1 V, VNO/NC = 4.5 V
DG2001E
(25 °C, unless otherwise noted) Axis Title Axis Title 4000 10000 20 10000
10 2000
I
Loss
0 0 ) -10 XTALK (pA (dB -20 -2000 1000 1000 K L -30 OIRR -4000
I
TA rrent
COM(OFF), VCOM = 4.5 V, VNO/NC = 1 V
ne ne ine ine -40 ne ne u -6000
I
-50
NO/NC(OFF), VCOM = 4.5 V, VNO/NC = 1 V
1st li 2nd li 2nd l RR, X 1st li 2nd li 2nd l -60 age C -8000
ICOM(ON), VCOM = 1 V
100 100 -70 Leak -10000 -80 Loss, OI
ICOM(OFF), VCOM = 1 V, VNO/NC = 4.5 V
-90 -12000 V+ = +5.5 V -100 V+ = +5 V -14000 10 -110 10 -40 -20 0 20 40 60 80 100K 1M 10M 100M 1G Temperature (°C) Frequency (Hz) 2nd line 2nd line
Leakage Current vs. Temperature Insertion Loss, Off-Isolation Crosstalk vs. Frequency
Axis Title Axis Title 5 10000 10000 10000 V+ = +5 V 1000 V+ = +5 V V
IN
= V+ or GND 4 ) 100 V+ = +3 V (nA (μA 1000 10 1000 3 V+ = +2 V rrent rrent u ne ne 1 ine ne ne ine u C V+ = +3 V y C V y 0.1
IN
= V+ or GND 1st li 2nd l 1st li 2 2nd li 2nd li 2nd l uppl 100 uppl 0.01 100 S S - - I+ 1 0.001 I+ 0.0001 0 10 0.00001 10 -40 -20 0 20 40 60 80 100 10 100 1000 10K 100K 1M 10M Temperature (°C) Input Switching Frequency (Hz) 2nd line 2nd line
Supply Current vs. Temperature Supply Current vs. Input Switching Frequency
Axis Title Axis Title 50 10000 45 10000 ) s 40 V+ = +2 V, tON 45 (n ) e 35 im (μA 40 1000 T g 30 1000 ine in V+ = +5 V, tON V+ = +3 V, t rrent h ON ne ne 25 ne ine u ne itc 35 V+ = +2 V, t C 2nd l w OFF y 1st li 2nd li 20 2nd l 1st li -S 2nd li F uppl 30 100 OF 15 100 S V+ = +3 V, t - , t OFF I+ 10 t ON 25 V+ = +5 V 5 V V+ = +5 V, t
IN
= 1.6 V OFF 20 10 0 10 -40 -20 0 20 40 60 80 100 -50 0 50 100 Temperature (°C) Temperature (°C) 2nd line 2nd line
Supply Current vs. Temperature Switching Time vs. Temperature and Supply Voltage
S18-0426-Rev. B, 23-Apr-18
6
Document Number: 76471 For technical questions, contact: analogswitchtechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
