Datasheet ECS-CTP-8.00-30-TR (ECS Inc.)
ManufacturerECS Inc.
DescriptionCeramic Resonator
Pages / Page3 / 1 — ECS-CTP. SMD Ceramic Resonator. Request a Sample. OPERATING CONDITIONS / …
File Format / SizePDF / 414 Kb
ECS-CTP. SMD Ceramic Resonator. Request a Sample. OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS. ECS-CTP SMD RESONATOR
Datasheet ECS-CTP-8.00-30-TR ECS Inc.
ECS-CTP SMD Ceramic Resonator
The ECS-CTP Series SMD ceramic resonator includes built in capacitors for reduced component count. The SMD Ceramic resonator is a low cost frequency control solution when absolute
Request a Sample
frequency accuracy is not important.
OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS ECS-CTP SMD RESONATOR PARAMETERS CONDITIONS ECS-CTP UNITS MIN TYP MAX
Frequency 1.84 20.00 MHz Frequency Tolerance @ +25°C ± 0.5 % 1.84 ~ 8.00 MHz ± 0.3 % Frequency Stability 8.01 ~ 12.00 MHz ± 0.2 % Over -40 ~ +85°C 12.1 ~ 20.00 MHz ±0.3 % 1.84 ~ 2.99 MHz 100 Ω • 6.0 x 3.0 mm package Equivalent Series 3.0 ~ 3.49 MHz 50 Ω • Industry Standard footprint Resistance (ESR) 3.5 ~ 12.00 MHz 30 Ω • Extended Temp. Range 12.1 ~ 20.0 MHz 60 Ω • Built-in Caps Withstanding Voltage DC, 5 s Max. 100 V
DIMENSIONS (mm)
DC Voltage 6 V Voltage Rating AC Voltage 15 Vp-p Insulation Resistance 10V, 1 Min. 500 MΩ Operating Temperature Topr -40 +85 °C Storage Temperature Tstg -55 +85 °C Aging (First Year) @ +25°C ±3°C ±0.1 % Aging (10 Year) @ +25°C ±3°C ±0.3 % Height 1.8 ±0.2 (1.84~3.5 MHz) 1.5 ±0.2 (3.51 ~ 12 MHz) 1.6 ±0.2 (12.1 ~ 20 MHz
PAD CONNECTIONS
1 In/Out 2 Gnd 3 Out/In
Figure 1)
Top, Side, and Bottom views
Figure 2)
Suggested Land Pattern
PART NUMBERING GUIDE: Example ECS-CTP-8.00-30-TR ECS -CTP FREQUENCY Built In PACKAGING CAPACITANCE
8.00 = 8.000 MHz Standard TR = *See Developed 30 = 30 pF Tape Frequencies Pg. 2 10 = 10 pF & Reel 15 = 15 pF 4K/Reel 22 = 22 pF *Contact ECS for availability of non-developed 33 = 33 pF frequen cies/non standard cap values. 39 = 39 pF Rev.2024
15351 West 109th Street
Lenexa, KS 66219
Phone: 913.782.7787
Fax: 913.782.6991
www.ecsxtal.com
