LTC2270 TIMING CHARACTERISTICSThe l denotes the specifications which apply over the full operating temperaturerange, otherwise specifications are at TA = 25°C. (Note 5)SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITSDigital Data Outputs (LVDS Mode) tD ENC to Data Delay CL = 5pF (Note 8) l 1.1 1.8 3.2 ns tC ENC to CLKOUT Delay CL = 5pF (Note 8) l 1 1.5 2.7 ns tSKEW DATA to CLKOUT Skew tD – tC (Note 8) l 0 0.3 0.6 ns Pipeline Latency 6.5 6.5 Cycles SPI Port Timing (Note 8) tSCK SCK Period Write Mode l 40 ns Readback Mode, CSDO = 20pF, RPULLUP = 2k l 250 ns tS CS to SCK Setup Time l 5 ns tH SCK to CS Setup Time l 5 ns tDS SDI Setup Time l 5 ns tDH SDI Hold Time l 5 ns tDO SCK Falling to SDO Valid Readback Mode, CSDO = 20pF, RPULLUP = 2k l 125 ns Note 1: Stresses beyond those listed under Absolute Maximum Ratings Note 6: Integral nonlinearity is defined as the deviation of a code from a may cause permanent damage to the device. Exposure to any Absolute best fit straight line to the transfer curve. The deviation is measured from Maximum Rating condition for extended periods may affect device the center of the quantization band. reliability and lifetime. Note 7: Offset error is the offset voltage measured from –0.5 LSB when Note 2: All voltage values are with respect to GND with GND and OGND the output code flickers between 0000 0000 0000 0000 and 1111 1111 shorted (unless otherwise noted). 1111 1111 in 2’s complement output mode. Note 3: When these pin voltages are taken below GND or above VDD, they Note 8: Guaranteed by design, not subject to test. will be clamped by internal diodes. This product can handle input currents Note 9: VDD = 1.8V, fSAMPLE = 20MHz, CMOS outputs, ENC+ = single-ended of greater than 100mA below GND or above VDD without latchup. 1.8V square wave, ENC– = 0V, input range = 2.1VP-P with differential drive, Note 4: When these pin voltages are taken below GND they will be 5pF load on each digital output unless otherwise noted. The supply current clamped by internal diodes. When these pin voltages are taken above VDD and power dissipation specifications are totals for the entire IC, not per they will not be clamped by internal diodes. This product can handle input channel. currents of greater than 100mA below GND without latchup. Note 10: Recommended operating conditions. Note 5: VDD = OVDD = 1.8V, fSAMPLE = 20MHz, LVDS outputs, differential ENC+/ENC– = 2VP-P sine wave, input range = 2.1VP-P with differential drive, unless otherwise noted. 2270f 8
