Datasheet AD8676 (Analog Devices) - 9
DescriptionUltra Precision, 36 V, 2.8 nV/√Hz Dual RRO Op Amp
Pages / Page12 / 9 — Data Sheet. AD8676. 160. 1000. ) B 140 (d IO 120. SOURCE. RAT N 100. 100. …
RevisionC
File Format / SizePDF / 345 Kb
Data Sheet. AD8676. 160. 1000. ) B 140 (d IO 120. SOURCE. RAT N 100. 100. –PSRR. (m T. JE E. – V. +PSRR. SINK. S R. E W O P. –20. 10k. 100k. 10M. 100M. 0.001. 0.01
Data Sheet AD8676 160 1000 ) B 140 (d IO 120 SOURCE RAT N 100 100 –PSRR (m T JE E – V +PSRR SINK S R E W O P –20 10k 100k 10M 100M 0.001 0.01
Data Sheet AD8676
±15 V and ±5 V, TA = 25°C, unless otherwise specified.
160 1000 ) B 140 (d IO 120 SOURCE RAT N 100 100 IO –PSRR V) CT 80 (m T JE E OU R 60 Y – V L S P +PSRR V P 40 10 U SINK S R 20 E W O P 0 –20 1 10 100 1k 10k 100k 1M 10M 100M
1 4 02
0.001 0.01 0.1 1 10 100
02 7- 7-
FREQUENCY (Hz)
48
LOAD CURRENT (mA)
48 06 06 Figure 21. Power Supply Rejection Ratio vs. Frequency Figure 24. Output Saturation Voltage vs. Output Load Current
126 15.0 RL = 2kΩ VS = ±15V B) 124 (d 14.9 IO ) V 122 ( E N RAT 14.8 AG IO T 120 L CT O JE V 14.7 RE UT 118 P Y L P UT P 14.6 U 116 H O G R S HI E W 14.5 114 O P 112 14.4 –40 –20 0 20 40 60 80 100 120
22 25 1
1 7- 7-
TEMPERATURE (°C)
48
TEMPERATURE (°C)
48 06 06 Figure 22. Power Supply Rejection Ratio vs. Temperature Figure 25. High Output Voltage, VOH vs. Temperature, VS = ±15 V
0.06 5.00 RL = 2kΩ VS = ±5V 0.04 4.95 ) V ( E 0.02 AG ) T V L 4.90 µ O ( E 0 V IS UT P NO 4.85 UT –0.02 H O G HI 4.80 –0.04 –0.06 4.75 0 1 2 3 4 5 6 7 8 9 10
3
25 -02 2 7- 87
TIME (s)
48 64
TEMPERATURE (°C)
0 06 Figure 23. Voltage Noise (0.1 Hz to 10 Hz) Figure 26. High Output Voltage, VOH vs. Temperature, VS = ±5 V Rev. C | Page 9 of 12 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
