Datasheet LT1072 - 3
Description1.25A High Efficiency Switching Regulator
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 206 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LT1072
denotes specifications which apply over the full operating temperature range. Unless otherwise specified, VIN = 15V, VC = 0.5V, VFB = VREF, output pin open. SYMBOL PARAMETER CONDITlONS MIN TYP MAX UNITS
VREF Reference Voltage Measured at Feedback Pin 1.224 1.244 1.264 V VC = 0.8V ● 1.214 1.244 1.274 V IB Feedback Input Current VFB = VREF 350 750 nA ● 1100 nA gm Error Amplifier ∆IC = ±25µA 3000 4400 6000 µmho Transconductance ● 2400 7000 µmho Error Amplifier Source or VC = 1.5V 150 200 350 µA Sink Current ● 120 400 µA Error Amplifier Clamp Hi Clamp, VFB = 1V 1.8 2.3 V Voltage Lo Clamp, VFB = 1.5V 0.25 0.38 0.52 V Reference Voltage Line 3V ≤ VIN ≤ VMAX ● 0.03 %/V Regulation VC = 0.8V %/V AV Error Amplifier Voltage Gain 0.9V ≤ VC ≤ 1.4V 500 800 V/V Minimum Input Voltage ● 2.6 3.0 V IQ Supply Current 3V ≤ VIN ≤ VMAX, VC = 0.6V 6 9 mA Control Pin Threshold Duty Cycle = 0 0.8 0.9 1.08 V ● 0.6 1.25 V Normal/Flyback Threshold on Feedback Pin 0.4 0.45 0.54 V VFB Flyback Reference Voltage lFB = 50µA 15 16.3 17.6 V ● 14 18 V Change in Flyback Reference Voltage 0.05 ≤ IFB ≤ 1mA 4.5 6.8 8.5 V Flyback Reference Voltage lFB = 50µA 0.01 0.03 %/V Line Regulation 3V ≤ VIN ≤ VMAX (Note 4) %/V Flyback Amplifier Transconductance (gm) ∆IC = ±10µA 150 300 650 µmho Flyback Amplifier Source VC = 0.6V Source ● 15 32 70 µA and Sink Current IFB = 50µA Sink ● 25 40 70 µA BV Output Switch Breakdown 3V ≤ VIN ≤ VMAX LT1072 ● 65 90 V Voltage ISW = 1.5mA LT1072HV ● 75 90 V LT1072S8 ● 60 80 V VSAT Output Switch ON Resistance (Note 2) ISW = 1.25A ● 0.6 1 Ω Control Voltage to Switch Current Transconductance 2 A/V ILIM Switch Current Limit Duty Cycle = 50% TJ ≥ 25°C ● 1.25 3 A Duty Cycle = 50% TJ < 25°C ● 1.25 3.5 A Duty Cycle = 80% (Note 3) ● 1 2.5 A ∆IIN Supply Current Increase 25 35 mA/A ∆ISW During Switch ON Time f Switching Frequency 35 40 45 kHz ● 33 47 kHz DC (max) Maximum Switch Duty Cycle 90 92 97 % Flyback Sense Delay Time 1.5 µs Shutdown Mode 3V ≤ VIN ≤ VMAX 100 250 µA Supply Current VC = 0.05V Shutdown Mode 3V ≤ VIN ≤ VMAX 100 150 250 mV Threshold Voltage ● 50 300 mV
Note 1:
Note 3:
For duty cycles (DC) between 50% and 80%, minimum of a device may be impaired. guaranteed switch current is given by ILIM = 0.833 (2 – DC).
Note 2:
Measured with VC in hi clamp, VFB = 0.8V.
Note 4:
VMAX = 55V for LT1072HV to avoid switch breakdown. 1072fc 3
