Datasheet AD797 (Analog Devices) - 6
DescriptionUltralow Distortion, Ultralow Noise Op Amp
Pages / Page19 / 6 — AD797. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. ) V± (EG. IV). …
RevisionK
File Format / SizePDF / 345 Kb
AD797. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. ) V± (EG. IV). RAN DE. .01µV/. L A. IC T. VER. HORIZONTAL SCALE (5sec/DIV)
AD797 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS ) V± (EG IV) RAN DE .01µV/ L A IC T VER HORIZONTAL SCALE (5sec/DIV)
AD797 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 20 ) V± (EG IV) 15 D RAN DE .01µV/ O (0 M E 10 L N- A O C M S M L A CO IC T UT 5 NP VER I 0
07 4 0 6- 00
0 5 10 15 20
6- 84
84
SUPPLY VOLTAGE (±V)
00 00 Figure 3. Input Common-Mode Voltage Range vs. Supply Voltage Figure 6. 0.1 Hz to 10 Hz Noise
20 0 V) (± 15 A) µ –0.5 G ( NI NT W E S G AT 10 CURRE –1.0 L +VOUT AS VO –V BI T OUT U UT P T U 5 INP –1.5 O 0
5
–2.0
00
0 5 10 15 20
08 6- 0
–60 –40 –20 0 20 40 60 80 100 120 140
6- 84
SUPPLY VOLTAGE (±V)
84 00
TEMPERATURE (°C)
00 Figure 4. Output Voltage Swing vs. Supply Voltage Figure 7. Input Bias Current vs. Temperature
30 140 ) VS = ±15V ) p A - p m 120 ( V( NT G N 20 I W 100 CURRE E S T SOURCE CURRENT G SINK CURRENT ATL RCUI -CI 80 VO T T 10 R PU T VS = ±5 HO U S O 60
6
0 40
00
10 100 1k 10k
6-
09 84
LOAD RESISTANCE (Ω)
0 00 6- 84
TEMPERATURE (°C)
00 Figure 5. Output Voltage Swing vs. Load Resistance Figure 8. Short-Circuit Current vs. Temperature Rev. K | Page 6 of 19 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION NOISE AND SOURCE IMPEDANCE CONSIDERATIONS LOW FREQUENCY NOISE WIDEBAND NOISE BYPASSING CONSIDERATIONS THE NONINVERTING CONFIGURATION THE INVERTING CONFIGURATION DRIVING CAPACITIVE LOADS SETTLING TIME DISTORTION REDUCTION Differential Line Receiver A General-Purpose ATE/Instrumentation I/O Driver Ultrasound/Sonar Imaging Preamp Amorphous (Photodiode) Detector Professional Audio Signal Processing—DAC Buffers OUTLINE DIMENSIONS ORDERING GUIDE
