UF5400, UF5401, UF5402, UF5403, UF5404, UF5405, UF5406, UF5407, UF5408 www.vishay.com Vishay General Semiconductor Soft Recovery Ultrafast Plastic RectifierFEATURES • Glass passivated pellet chip junction • Ultrafast reverse recovery time • Low forward voltage drop • Low switching losses, high efficiency • High forward surge capability • Solder dip 275 °C max. 10 s, per JESD 22-B106 DO-201AD • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912 TYPICAL APPLICATIONS For use in high frequency rectification and freewheeling application in switching mode converters and inverters for PRIMARY CHARACTERISTICS consumer, computer and telecommunication. IF(AV) 3.0 A 50 V, 100 V, 200 V, 300 V, 400 V, VRRM MECHANICAL DATA 500 V, 600 V, 800 V, 1000 V Case: DO-201AD IFSM 150 A Molding compound meets UL 94 V-0 flammability rating trr 50 ns, 75 ns Base P/N-E3 - RoHS-compliant, commercial grade VF 1.0 V, 1.7 V Terminals: Matte tin plated leads, solderable per TJ max. 150 °C J-STD-002 and JESD 22-B102 Package DO-201AD E3 suffix meets JESD 201 class 1A whisker test Diode variations Single die Polarity: Color band denotes cathode end MAXIMUM RATINGS (TA = 25 °C unless otherwise noted) PARAMETERSYMBOL UF5400 UF5401 UF5402 UF5403 UF5404 UF5405 UF5406 UF5407 UF5408 UNIT Maximum repetitive peak V reverse voltage RRM 50 100 200 300 400 500 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 210 280 350 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 300 400 500 600 800 1000 V Maximum average forward rectified current, 0.375" (9.5 mm) IF(AV) 3.0 A lead length at TA= 55 °C Peak forward surge current 8.3 ms single half sine-wave IFSM 150 A superimposed on rated load Operating junction and T storage temperature range J, TSTG -55 to +150 °C Revision: 19-Feb-16 1 Document Number: 88756 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
