Datasheet AD8505, AD8506, AD8508 (Analog Devices) - 3
Description20 µA Maximum, RRIO, Zero Input Crossover Distortion Single Op Amp
Pages / Page20 / 3 — AD8505/AD8506/AD8508. SPECIFICATIONS ELECTRICAL CHARACTERISTICS—1.8 V …
RevisionF
File Format / SizePDF / 665 Kb
AD8505/AD8506/AD8508. SPECIFICATIONS ELECTRICAL CHARACTERISTICS—1.8 V OPERATION. Table 1. Parameter Symbol. Conditions. Min. Typ
AD8505/AD8506/AD8508 SPECIFICATIONS ELECTRICAL CHARACTERISTICS—1.8 V OPERATION Table 1 Parameter Symbol Conditions Min Typ
VSY = 1.8 V, VCM = VSY/2, TA = 25°C, RL = 100 kΩ to GND, unless otherwise noted.
Table 1. Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 0 V ≤ VCM ≤ 1.8 V 0.5 2.5 mV −40°C ≤ TA ≤ +125°C 3.5 mV Input Bias Current IB 1 10 pA −40°C ≤ TA ≤ +85°C 100 pA −40°C ≤ TA ≤ +125°C 600 pA Input Offset Current IOS 0.5 5 pA −40°C ≤ TA ≤ +85°C 50 pA −40°C ≤ TA ≤ +125°C 100 pA Input Voltage Range −40°C ≤ TA ≤ +125°C 0 1.8 V Common-Mode Rejection Ratio CMRR 0 V ≤ VCM ≤ 1.8 V 85 100 dB −40°C ≤ TA ≤ +85°C 85 dB −40°C ≤ TA ≤ +125°C 80 dB Large-Signal Voltage Gain AVO 0.05 V ≤ VOUT ≤ 1.75 V, 95 115 dB RL = 100 kΩ to VCM −40°C ≤ TA ≤ +125°C 95 dB Offset Voltage Drift ΔVOS/ΔT −40°C ≤ TA ≤ +125°C 2.5 μV/°C Input Resistance RIN 220 GΩ Input Capacitance, Differential Mode CINDM 3 pF Input Capacitance, Common Mode CINCM 4.2 pF OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 100 kΩ to GND 1.78 1.79 V −40°C ≤ TA ≤ +125°C 1.78 V RL = 10 kΩ to GND 1.65 1.75 V −40°C ≤ TA ≤ +125°C 1.65 V Output Voltage Low VOL RL = 100 kΩ to VSY 2 5 mV −40°C ≤ TA ≤ +125°C 5 mV RL = 10 kΩ to VSY 12 25 mV −40°C ≤ TA ≤ +125°C 25 mV Short-Circuit Limit ISC VOUT = VSY or GND ±4.5 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = 1.8 V to 5 V 100 110 dB −40°C ≤ TA ≤ +85°C 100 dB −40°C ≤ TA ≤ +125°C 95 dB Supply Current per Amplifier ISY AD8506/AD8508 VOUT = VSY/2 16.5 20 μA −40°C ≤ TA ≤ +125°C 25 μA AD8505 VOUT = VSY/2 16.5 24 μA −40°C ≤ TA ≤ +125°C 27.5 μA DYNAMIC PERFORMANCE Slew Rate SR RL = 100 kΩ, CL = 10 pF, G = 1 13 mV/μs Gain Bandwidth Product GBP RL = 1 MΩ, CL = 20 pF, G = 1 95 kHz Phase Margin ΦM RL = 1 MΩ, CL = 20 pF, G = 1 60 Degrees NOISE PERFORMANCE Voltage Noise en p-p f = 0.1 Hz to 10 Hz 2.8 μV p-p Voltage Noise Density en f = 1 kHz 45 nV/√Hz Current Noise Density in f = 1 kHz 15 fA/√Hz Rev. E | Page 3 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—1.8 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PULSE OXIMETER CURRENT SOURCE FOUR-POLE, LOW-PASS BUTTERWORTH FILTER FOR GLUCOSE MONITOR OUTLINE DIMENSIONS ORDERING GUIDE
