Datasheet OP400 (Analog Devices) - 6 Manufacturer Analog Devices Description Low Offset, Low Power Quad Op Amp Pages / Page 16 / 6 — OP400. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. S = ±15V. A = … Revision I File Format / Size PDF / 342 Kb Document Language English
OP400. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. S = ±15V. A = 25°C. 120. VS = ±15V. (μV). A) p. 110. OLTA. ET V. CURRE. 100. T E S F. OFFS. N A
Model Line for this Datasheet Text Version of Document OP400 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 3 V T S = ±15V A = 25°C 120 VS = ±15V (μV) A) p GE ( 110 NT 2 OLTA ET V CURRE 100 T E S F OFFS F IN 1 O 90 GE UT N A INP H C 80 007 004 00304-0 00304-–75 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 TEMPERATURE (°C) TIME (Minutes) Figure 4. Warmup Drift Figure 7. Input Offset Current vs. Temperature70 1.1 VS = ±15V 60 1.0 (μV) A) n GE ( 50 NT 0.9 OLTA 40 ET V CURRE AS 0.8 BI 30 T OFFS UT PU INP IN 0.7 20 005 00810 00304-0.6 00304-–75 –50 –25 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 TEMPERATURE (°C) COMMON-MODE VOLTAGE (V) Figure 5. Input Offset Voltage vs. Temperature Figure 8. Input Bias Current vs. Common-Mode Voltage2.0 140 V TA = 25°C S = ±15V VS = ±15V 120 1.6 B) d A) n N ( 100 ( IO NT CT 1.2 JE 80 RE CURRE DE AS 60 0.8 O M BI N- UT O 40 M INP M 0.4 CO 20 006 0090 00304-0 00304-–75 –50 –25 0 25 50 75 100 125 1 10 100 1k 10k 100k TEMPERATURE (°C) FREQUENCY (Hz) Figure 6. Input Bias Current vs. Temperature Figure 9. Common-Mode Rejection vs. Frequency Rev. H | Page 6 of 16 Document Outline Features General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Dual Low Power Instrumentation Amplifier Bipolar Current Transmitter Differential Output Instrumentation Amplifier Multiple Output Tracking Voltage Reference Outline Dimensions Ordering Guide SMD Parts and Equivalents
