Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V (Texas Instruments)
ManufacturerTexas Instruments
DescriptionDual Differential Comparators
Pages / Page37 / 1 — LM193,. LM293. , LM293A. , LM393. , LM393A. , LM2903. , LM2903V. LM393, …
RevisionY
LM193,. LM293. , LM293A. , LM393. , LM393A. , LM2903. , LM2903V. LM393, LM293, LM193, LM2903 Dual Differential Comparators. 1 Features
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V Texas Instruments, Revision: Y
link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 1 Product Order Technical Tools & Support & Reference Folder Now Documents Software Community Design
LM193, LM293 , LM293A , LM393 , LM393A , LM2903 , LM2903V
SLCS005Z – OCTOBER 1979 – REVISED OCTOBER 2017
LM393, LM293, LM193, LM2903 Dual Differential Comparators 1 Features 3 Description
• Single-Supply or Dual Supplies These devices consist of two independent voltage 1 comparators that are designed to operate from a • Wide Range of Supply Voltage single power supply over a wide range of voltages. – Maximum Rating: 2 V to 36 V Operation from dual supplies also is possible as long – Tested to 30 V: Non-V Devices as the difference between the two supplies is 2 V to 36 V, and V – Tested to 32 V: V-Suffix Devices CC is at least 1.5 V more positive than the input common-mode voltage. Current drain is • Low Supply-Current Drain Independent of Supply independent of the supply voltage. The outputs can Voltage: 0.4 mA (Typical) Per Comparator be connected to other open-collector outputs to • Low Input Bias Current: 25 nA (Typical) achieve wired-AND relationships. • Low Input Offset Current: 3 nA (Typical) (LM193) The LM193 device is characterized for operation from • Low Input Offset Voltage: 2 mV (Typical) −55°C to +125°C. The LM293 and LM293A devices are characterized for operation from −25°C to +85°C. • Common-Mode Input Voltage Range The LM393 and LM393A devices are characterized Includes Ground for operation from 0°C to 70°C. The LM2903, • Differential Input Voltage Range Equal to LM2903V, and LM2903AV devices are characterized Maximum-Rated Supply Voltage: ±36 V for operation from −40°C to +125°C. • Low Output Saturation Voltage
Device Information(1)
• Output Compatible With TTL, MOS, and CMOS
PART NUMBER PACKAGE BODY SIZE (NOM)
• On Products Compliant to MIL-PRF-38535, LM193D, LM293D, All Parameters Are Tested Unless Otherwise LM293AD, LM393D, Noted. On All Other Products, Production LM393AD, LM2903D, SOIC (8) 4.90 mm x 6.00 mm Processing Does Not Necessarily Include Testing LM2903QD, LM2903VQD, of All Parameters. LM2903AVQD LM293DGK,
2 Applications
LM293ADGK, LM393DGK, VSSOP (8) 3.00 mm x 5.00 mm • Chemical or Gas Sensor LM393ADGK, • Desktop PC LM2903DGK • Motor Control: AC Induction LM293P, LM393P, PDIP (8) 9.50 mm × 6.30 mm LM393AP, LM2903P • Weigh Scale LM393PS, LM393APS, SO (8) 6.20 mm x 7.90 mm LM2903PS LM393PW, LM393APW, LM2903PW, TSSOP (8) 6.40 mm x 3.00 mm LM2903VQPW, LM2903AVQPW LM193JG CDIP (8) 10.00 mm x 7.00 mm LM193FK LCCC (20) 9.00 mm x 9.00 mm (1) For all available packages, see the orderable addendum at the end of the data sheet.
Simplified Schematic IN+ OUT IN−
1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information LM293, LM393, LM2903 (all suffixes) 6.5 Thermal Information LM193 6.6 Electrical Characteristics for LM193, LM293, and LM393 (without A suffix) 6.7 Electrical Characteristics for LM293A and LM393A 6.8 Electrical Characteristics for LM2903, LM2903V, and LM2903AV 6.9 Switching Characteristics (all devices) 6.10 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.4 Device Functional Modes 7.4.1 Voltage Comparison 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.2.1 Input Voltage Range 8.2.2.2 Minimum Overdrive Voltage 8.2.2.3 Output and Drive Current 8.2.2.4 Response Time 8.2.3 Application Curves 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Related Links 11.2 Receiving Notification of Documentation Updates 11.3 Community Resources 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Mechanical, Packaging, and Orderable Information
