Datasheet LM1117 (Texas Instruments) - 8
Manufacturer | Texas Instruments |
Description | 800-mA Low-Dropout Linear Regulator |
Pages / Page | 36 / 8 — LM1117. www.ti.com. LM1117I Electrical Characteristics (continued). … |
Revision | N |
File Format / Size | PDF / 2.8 Mb |
LM1117. www.ti.com. LM1117I Electrical Characteristics (continued). PARAMETER. TEST CONDITIONS. MIN(1). TYP(2). MAX(1). UNIT
LM1117
SNOS412N – FEBRUARY 2000 – REVISED JANUARY 2016
www.ti.com LM1117I Electrical Characteristics (continued)
unless otherwise specified, TJ = 25°C.
PARAMETER TEST CONDITIONS MIN(1) TYP(2) MAX(1) UNIT
TJ = 25°C 1.1 over the junction IOUT = 100 mA V temperature range 1.3 –40°C to 125°C TJ = 25°C 1.15 over the junction VIN-V OUT Dropout Voltage(4) IOUT = 500 mA V temperature range 1.35 –40°C to 125°C TJ = 25°C 1.2 over the junction IOUT = 800 mA V temperature range 1.4 –40°C to 125°C ILIMIT Current Limit VIN – VOUT = 5 V, TJ = 25°C 800 1200 1500 mA TJ = 25°C 1.7 Minimum Load LM1117I-ADJ over the junction mA Current(5) VIN = 15 V temperature range 5 –40°C to 125°C TJ = 25°C 5 LM1117I-3.3 over the junction mA VIN ≤ 15 V temperature range 15 –40°C to 125°C Quiescent Current TJ = 25°C 5 LM1117I-5.0 over the junction mA VIN ≤ 15 V temperature range 15 –40°C to 125°C Thermal Regulation TA = 25°C, 30ms Pulse 0.01 0.1 %/W TJ = 25°C 75 fRIPPLE = 120 Hz, VIN – VOUT = 3 V over the junction Ripple Regulation dB VRIPPLE = 1 VPP temperature range 60 –40°C to 125°C TJ = 25°C 60 Adjust Pin Current μA over the junction temperature range –40°C to 125°C 120 TJ = 25°C 0.2 Adjust Pin Current 10 ≤ IOUT ≤ 800 mA, over the junction µA Change 1.4 V ≤ VIN – VOUT ≤ 10 V temperature range 10 –40°C to 125°C Temperature 0.5% Stability Long Term Stability TA = 125°C, 1000 Hrs 0.3% RMS Output Noise (% of VOUT), 10 Hz ≤ f ≤ 10 kHz 0.003% (4) The dropout voltage is the input/output differential at which the circuit ceases to regulate against further reduction in input voltage. It is measured when the output voltage has dropped 100 mV from the nominal value obtained at VIN = VOUT + 1.5 V. (5) The minimum output current required to maintain regulation. 8 Submit Documentation Feedback Copyright © 2000–2016, Texas Instruments Incorporated Product Folder Links: LM1117 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 LM1117 Electrical Characteristics 6.6 LM1117I Electrical Characteristics 6.7 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Load Regulation 7.4 Device Functional Modes 7.4.1 Protection Diodes 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.2.1 External Capacitors 8.2.3 Application Curve 8.3 System Examples 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.1.1 Heatsink Requirements 10.2 Layout Example 11 Device and Documentation Support 11.1 Community Resources 11.2 Trademarks 11.3 Electrostatic Discharge Caution 11.4 Glossary 12 Mechanical, Packaging, and Orderable Information Page 1 Page 1
