Datasheet TL081, TL081A, TL081B, TL082, TL082A, TL082B, TL084, TL084A, TL084B (Texas Instruments) - 9
Description | TL08xx JFET-input operational amplifier |
Pages / Page | 51 / 9 — TL081. , TL081A,. TL081B. , TL082,. TL082A. TL082B,. TL084. , TL084A,. … |
Revision | I |
File Format / Size | PDF / 2.5 Mb |
TL081. , TL081A,. TL081B. , TL082,. TL082A. TL082B,. TL084. , TL084A,. TL084B. www.ti.com. 6.9 Typical Characteristics
link to page 13 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11
TL081 , TL081A, TL081B , TL082, TL082A TL082B, TL084 , TL084A, TL084B www.ti.com
SLOS081I – FEBRUARY 1977 – REVISED MAY 2015
Data at high and low temperatures are applicable only within the rated operating free-air temperature ranges of the various devices. The Figure numbers referenced in the following graphs are located in Parameter Measurement Information.
Table 1. Table of Graphs Figure
versus Frequency Figure 1, Figure 2, Figure 3 versus Free-air temperature Figure 4 VOM Maximum peak output voltage versus Load resistance Figure 5 versus Supply voltage Figure 6 Large-signal differential voltage versus Free-air temperature Figure 7 amplification versus Load resistance Figure 8 AVD versus Frequency with feed-forward Differential voltage amplification Figure 9 compensation PD Total power dissipation versus Free-air temperature Figure 10 versus Free-air temperature Figure 11 ICC Supply current versus Supply voltage Figure 12 IIB Input bias current versus Free-air temperature Figure 13 Large-signal pulse response versus Time Figure 14 VO Output voltage versus Elapsed time Figure 15 CMRR Common-mode rejection ratio versus Free-air temperature Figure 16 Vn Equivalent input noise voltage versus Frequency Figure 17 THD Total harmonic distortion versus Frequency Figure 18 ±
15
15 VCC
15 V RL = 10 kΩ R V V L = 2 kΩ TA = 25
C − TA = 25
C − e
12.5 See Figure 2 e
12.5 VCC
15 V g g See Figure 2 lta lta o o t V t V
10 u u
10 VCC
10 V tp tp u u VCC
10 V k O k O a
7.5 a e e
7.5 m P m P u u
5 V im CC
5 V im
5 x x a a M M VCC
5 V − − M
2.5 M
2.5 O OM O OM V V 0 0 100 1 k 10 k 100 k 1 M 10 M 100 1 k 10 k 100 k 1 M 10 M f − Frequency − Hz f − Frequency − Hz Figure 1. Maximum Peak Output Voltage Figure 2. Maximum Peak Output Voltage vs vs Frequency Frequency
Copyright © 1977–2015, Texas Instruments Incorporated Submit Documentation Feedback 9 Product Folder Links: TL081 TL081A TL081B TL082 TL082A TL082B TL084 TL084A TL084B Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for TL08xC, TL08xxC, and TL08xI 6.6 Electrical Characteristics for TL08xM and TL084x 6.7 Operating Characteristics 6.8 Dissipation Rating Table 6.9 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Total Harmonic Distortion 8.3.2 Slew Rate 8.4 Device Functional Modes 9 Applications and Implementation 9.1 Application Information 9.2 Typical Applications 9.2.1 Inverting Amplifier Application 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.3 Application Curve 9.3 System Examples 9.3.1 General Applications 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Examples 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Community Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, and Orderable Information
