Datasheet TL074, TL074A -TL074B (STMicroelectronics) - 3
Manufacturer | STMicroelectronics |
Description | LOW NOISE J-FET QUAD OPERATIONAL AMPLIFIERS |
Pages / Page | 11 / 3 — TL074 - TL074A - TL074B. ELECTRICAL CHARACTERISTICS. TL074I,M,AC,AI,AM,. … |
File Format / Size | PDF / 302 Kb |
TL074 - TL074A - TL074B. ELECTRICAL CHARACTERISTICS. TL074I,M,AC,AI,AM,. TL074C. Symbol. Parameter. BC,BI,BM. Unit. Min. Typ. Max
TL074 - TL074A - TL074B ELECTRICAL CHARACTERISTICS
VCC = ±15V, Tamb = +25°C (unless otherwise specified)
TL074I,M,AC,AI,AM, TL074C Symbol Parameter BC,BI,BM Unit Min. Typ. Max. Min. Typ. Max.
Input Offset Voltage (Rs = 50Ω) mV Tamb = +25°C TL074 3 10 3 10 TL074A 3 6 Vio TL074B 1 3 T 13 13 min ≤ Tamb ≤ Tmax TL074 TL074A 7 TL074B 5 DVio Input Offset Voltage Drift 10 10 µV/°C Input Offset Current - note 1) Iio Tamb = +25°C 5 100 5 100 pA T 4 10 nA min ≤ Tamb ≤ Tmax Input Bias Current -note 1 I T ib amb = +25°C 20 200 30 200 pA Tmin ≤ Tamb ≤ Tmax 20 20 nA Large Signal Voltage Gain (RL = 2kΩ, Vo = ±10V) V/mV Avd Tamb = +25°C 50 200 25 200 T 25 15 min ≤ Tamb ≤ Tmax Supply Voltage Rejection Ratio (RS = 50Ω) dB SVR Tamb = +25°C 80 86 70 86 T 80 70 min ≤ Tamb ≤ Tmax Supply Current, no load, per amplifier mA I T CC amb = +25°C 1.4 2.5 1.4 2.5 Tmin ≤ Tamb ≤ Tmax 2.5 2.5 ±11 +15 ±11 +15 V Vicm Input Common Mode Voltage Range -12 -12 Common Mode Rejection Ratio (RS = 50Ω) dB CMR Tamb = +25°C 80 86 70 86 T 80 70 min ≤ Tamb ≤ Tmax Output Short-circuit Current mA I T os amb = +25°C 10 40 60 10 40 60 Tmin ≤ Tamb ≤ Tmax 10 60 10 60 Output Voltage Swing V Tamb = +25°C RL = 2kΩ 10 12 10 12 ±Vopp RL = 10kΩ 12 13.5 12 13.5 Tmin ≤ Tamb ≤ Tmax RL = 2kΩ 10 10 RL = 10kΩ 12 12 Slew Rate (T V/µs SR amb = +25°C) Vin = 10V, RL = 2kΩ, CL = 100pF, unity gain 8 13 8 13 Rise Time (T µs t amb = +25°C) r Vin = 20mV, RL = 2kΩ, CL = 100pF, unity gain 0.1 0.1 Overshoot (T % K amb = +25°C) ov Vin = 20mV, RL = 2kΩ, CL = 100pF, unity gain 10 10 Gain Bandwidth Product (Tamb = +25°C) MHz GBP Vin = 10mV, RL = 2kΩ, CL = 100pF, f= 100kHz 2 3 2 3 Ri Input Resistance 1012 1012 Ω 3/11
