Datasheet TLV431, TLV431A, TLV431B (Texas Instruments) - 6
ManufacturerTexas Instruments
DescriptionTLV431x Low-Voltage Adjustable Precision Shunt Regulator
Pages / Page55 / 6 — TLV431. , TLV431A,. TLV431B. www.ti.com. 6.6 Electrical Characteristics …
RevisionX
TLV431. , TLV431A,. TLV431B. www.ti.com. 6.6 Electrical Characteristics for TLV431A. TLV431A. PARAMETER. TEST CONDITIONS. UNIT. MIN. TYP. MAX
TLV431 , TLV431A, TLV431B www.ti.com 6.6 Electrical Characteristics for TLV431A TLV431A PARAMETER TEST CONDITIONS UNIT MIN TYP MAX
link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16
SLVS139W – JULY 1996 – REVISED MARCH 2018
at 25°C free-air temperature (unless otherwise noted)
TA = 25°C 1.228 1.24 1.252 V TLV431AC 1.221 1.259 V KA = VREF, REF Reference voltage V I TA = full range(1) K = 10 mA TLV431AI 1.215 1.265 (see Figure 22) TLV431AQ 1.209 1.271 TLV431AC 4 12 V V V REF deviation over full KA = VREF, IK = 10 mA (1) REF(dev) TLV431AI 6 20 mV temperature range(2) (see Figure 22) TLV431AQ 11 31 D R V EF Ratio of VREF change in cathode VKA = VREF to 6 V, IK = 10 mA –1.5 –2.7 mV/V D voltage change (see Figure 23) K V A IK = 10 mA, R1 = 10 kΩ, Iref Reference terminal current R2 = open 0.15 0.5 µA (see Figure 23) TLV431AC 0.05 0.3 I I I ref deviation over full temperature K = 10 mA, R1 = 10 kΩ, ref(dev) TLV431AI 0.1 0.4 µA range(2) R2 = open(1) (see Figure 23) TLV431AQ 0.15 0.5 Minimum cathode current for TLV431AC/AI 55 80 IK(min) V µA regulation KA = VREF (see Figure 22) TLV431AQ 55 100 IK(off) Off-state cathode current VREF = 0, VKA = 6 V (see Figure 24) 0.001 0.1 µA |zKA| Dynamic impedance(3) VKA = VREF, f ≤ 1 kHz, IK = 0.1 mA to 15 mA 0.25 0.4 Ω (see Figure 22) (1) Full temperature ranges are –40°C to 125°C for TLV431Q, –40°C to 85°C for TLV431I, and 0°C to 70°C for TLV431C. (2) The deviation parameters VREF(dev) and Iref(dev) are defined as the differences between the maximum and minimum values obtained over the rated temperature range. The average full-range temperature coefficient of the reference input voltage, αVREF, is defined as: æ V ö REF(dev ) 6 ´ 10 ç ÷ æ ppm V T = 25 C ° ö è ø REF ( A ) aV = ç ÷ REF è C ° ø T D A where ΔTA is the rated operating free-air temperature range of the device. αVREF can be positive or negative, depending on whether minimum VREF or maximum VREF, respectively, occurs at the lower temperature. V D KA zka = (3) The dynamic impedance is defined as I D K spacer When the device is operating with two external resistors (see Figure 23), the total dynamic impedance of the circuit is defined as: V D R1 æ ö z ¢ = » z ´ 1 ç + ÷ ka ka I D è R2 ø 6 Submit Documentation Feedback Copyright © 1996–2018, Texas Instruments Incorporated Product Folder Links: TLV431 TLV431A TLV431B Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for TLV431 6.6 Electrical Characteristics for TLV431A 6.7 Electrical Characteristics for TLV431B 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.4 Device Functional Modes 8.4.1 Open Loop (Comparator) 8.4.2 Closed Loop 9 Applications and Implementation 9.1 Application Information 9.2 Typical Applications 9.2.1 Comparator With Integrated Reference (Open Loop) 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.3 Application Curves 9.2.2 Shunt Regulator/Reference 9.2.2.1 Design Requirements 9.2.2.2 Detailed Design Procedure 9.2.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Receiving Notification of Documentation Updates 12.4 Community Resources 12.5 Trademarks 12.6 Electrostatic Discharge Caution 12.7 Glossary 13 Mechanical, Packaging, and Orderable Information
